Stator Cover oil leak
- darwinvin
darwinvin@yahoo.com
Post edited by: darwinvin, at: 2007/04/04 07:56[img size=150]
Post edited by: darwinvin, at: 2007/04/04 07:57
- Thank you received: 2098
- steell
I'll move it to the engine forum for you.
- StreetfighterKz
- Thank you received: 117
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter (work in progress)
1983 Gpz750 Resto-Mod
1989 Vmax
- nads.com
- outatimeoutlaw
- Pterosaur
- Visitor
PATTON is 100% right! Its the only source I know of. When I did mine I also used brake cleaner to make sure there was NO OIL, Then when you are putting the wires thruogh the grommett don't get the holes (perforated for you )too big and put silicone on the wires so that when you pull them into place you are pulling the silicone into the holes in the new grommet. Works every time.
Dittos. Bin there, dun that.
- Alex_KZ1K
