Stator Cover oil leak
  • darwinvin
  • darwinvin's Avatar Topic Author
04 Apr 2007 04:52
#126344
Just replaced the gasket on my 81' k1. Now I have a leak where the wires are. Any help?
[email protected]
Post edited by: darwinvin, at: 2007/04/04 07:56[img size=150]
Post edited by: darwinvin, at: 2007/04/04 07:57
Re: Stator Cover oil leak
04 Apr 2007 05:52
#126353
  • steell
  • steell's Avatar
04 Apr 2007 07:39
#126387
Did you really mean to post this in the carb forum?? :D
I'll move it to the engine forum for you.
  • StreetfighterKz
  • StreetfighterKz's Avatar
04 Apr 2007 08:41
#126401
I always put a bead of semi-drying gasket sealer around the grommet with an extra dab where the paper gasket goes. Seems to work good so far.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • nads.com
  • nads.com's Avatar
04 Apr 2007 12:07
#126431
If the wires are loose in the rubber it still won't seal.
  • outatimeoutlaw
  • outatimeoutlaw's Avatar
07 Apr 2007 13:12
#127427
PATTON is 100% right! Its the only source I know of. When I did mine I also used brake cleaner to make sure there was NO OIL, Then when you are putting the wires thruogh the grommett don't get the holes (perforated for you )too big and put silicone on the wires so that when you pull them into place you are pulling the silicone into the holes in the new grommet. Works every time.
  • Pterosaur
  • Pterosaur's Avatar
07 Apr 2007 13:23
#127432
Dittos. Bin there, dun that. ;)
  • Alex_KZ1K
  • Alex_KZ1K's Avatar
07 Apr 2007 13:35
#127435
I just cleaned mine out really good with brake clean and filled it up with RTV... hasn't leaked yet.
