Contradictory
- Bicycle Lee
Re: Contradictory
06 Apr 2007 11:08
Anybody? Is removing and replacing the pilot jets as self explanatory as the main jets?
1978 KZ1000 police
- Duck
- e vica na i sau na ga
Re: Contradictory
06 Apr 2007 14:21
Which carbs do you have?
Find the diagrams.
All carbs are easy once you have an assembly diagram and a circuit diagram.
Find the diagrams.
- Wizzard
Re: Contradictory
06 Apr 2007 14:34
There should be no need to run different mains in the iner or outter like the carb guy said and you'll be fine. As for the pilots they should be in side the bowl and eaithe be the smallest flat head in there or in side a small hole. The # will be stamped on the side.
1977 KZ 1000
4-1 Headder
K&N filter
530 Chain & Sprokets
Rear Air Shocks
4-1 Headder
K&N filter
Rear Air Shocks
