carb sync
- boomboom45
carb sync
25 Mar 2007 16:15
anyone have, or know where i can get a carb sync tool? checked flea bay, looking for something cheaper.
- OKC_Kent
- boomboom45
- indykaw77
Re: carb sync
26 Mar 2007 15:58
Cool tool! Just click on the part that says
The $1.55 carb synchronizer.....it'll take ya right to the page....
Kawasaki Motorcycles...because cars lean th wrong way!
- N0NB
- Blue handles better
Re: carb sync
26 Mar 2007 16:32
Z1 Enterprises has one that uses individual gauges for about $50.
Motion Pro was rumored to be replacing their mercury filled job with something else, but their site shows nothing like that at the moment.
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel
- boomboom45
Re: carb sync
26 Mar 2007 17:58
thanks for the help guys. anyone know if this would work if i put 4 hoses on it?
- EsaPro
Re: carb sync
26 Mar 2007 18:10
Funny, I was searching today for manometers, and found the link above, as well as
This Link
I never though bagpipes and bikes had anything in common!
I hope to sync my twin using the $1.55 method this week(end).
Jim
79 KZ750 Twin (Fun!)
07 Yamaha 1300 (Plush!)
- RetroRiceRocketRider
Re: carb sync
26 Mar 2007 20:44
boomboom45 wrote:
All you need to do is sync carbs #1 & #2, then match carb #3 to #2, and finally match #4 to #3.
Or synch #1 and #2 (making sure to jot down the readings exactely), then swap the hoses over to #3 and #4 and just match those readings.
If you get a yard stick that's wide enough, you could just pony up with another $0.84 and run another pair of hoses on the yard stick like you're thinking.
Which would probably be the best way to go, since all 4 readings will be side-by-side and easier to match up.
Covina, So Calif!
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
89 GSX1100F Katana = SLEEPING
78 KZ650-B2 = SOLD
84 ZN700 LTD = SOLD
84 ZX750 GPz = SOLD
- H1Vindicator
Last edit: 20 Feb 2013 19:10 by H1Vindicator.
- wiredgeorge
Re: carb sync
27 Mar 2007 07:20
I have to respectfully disagree... Since all four slides hang from a common rod (bolted onto the rod solidly), when you change the slide height of one via its adjuster screw, the other three change a bit in some cases. Thus, if you get one and two carbs balanced and move the gauge to 2 and 3, you WILL often change #1 again. I have seen this happen a zillion times while syncing carbs. OK... this arrangement COULD work with FOUR pieces of clear tubing and the oil in each but I would advise to go to the hobby store and buy some plastic beads that are the same diameter as the ID of the tubing. Carefully make some holes in the beads; ensuring the holes are equal size. These beads are now RESTRICTORS. You won't have to have the tubing 9 miles long so as to avoid sucking the oil into your engine. The restrictors decrease engine vacuum pulling up the oil equally if the holes are the same size. Without restrictors on mercury gauges you would have the same problem. Even then, if you rev the engine enough and have the slides almost shut, the mercury can bounce and can sometimes get sucked into your engine. I guess the restictors also make it harder to suck the mercury (or oil in) just by being in the line. All commercial manometers will have the little beads... You can stick most any round thing in there that will stay as long as it has a small hole.
boomboom45 wrote:thanks for the help guys. anyone know if this would work if i put 4 hoses on it?
- JimatMilkyWay
Re: carb sync
28 Mar 2007 19:37
wiredgeorge wrote:
What size bit is used to drill the beads? #60?
George do you have a pic. The restrictors do not slide in the tube, right? They are wedged at the top end of the 4 individual tubes with the holes in the bead restrictors in-line with the tubes?.... I would advise to go to the hobby store and buy some plastic beads that are the same diameter as the ID of the tubing. Carefully make some holes in the beads; ensuring the holes are equal size. These beads are now RESTRICTORS. You won't have to have the tubing 9 miles long so as to avoid sucking the oil into your engine. The restrictors decrease engine vacuum pulling up the oil equally if the holes are the same size. Without restrictors on mercury gauges you would have the same problem. Even then, if you rev the engine enough and have the slides almost shut, the mercury can bounce and can sometimes get sucked into your engine. I guess the restictors also make it harder to suck the mercury (or oil in) just by being in the line. All commercial manometers will have the little beads... You can stick most any round thing in there that will stay as long as it has a small hole.
- CoreyClough
- GPz550 Addiction
Re: carb sync
29 Mar 2007 05:00
I bought a Motion Pro Carb Sync Tool off a guy on craigslist for $40.00. Looks brand new. These are the things he's talking about in the picture:
These are the adapters, but not sure what the restrictore do? Do the settle the mercury down from jumping around, to get a more accurate reading?:blink:
'85 GPz550(ZX550-A2)
