Carb Questions
  • JimatMilkyWay
  • JimatMilkyWay's Avatar
Re: Carb Questions
25 Jan 2007 20:01
#108220
ronjones wrote:
.... I think mine was running and peeing, at the same time,....
I tried that once myself. You talk about a mess. I'm glad it was a nice, warm night as my leg 'bout froze as it was.
  • DemonSpeed
  • DemonSpeed's Avatar Topic Author
Re: Carb Questions
25 Jan 2007 21:32
#108236
no the fuel line is hooked up right... i messed w/ the floats a bit today i and put the back together and the carb on the left stopped leakin and now its the two carbs on right are now leaking (3,4) i didnt start it (battery was dead) all the slides are working and the needles slide fine
  • ronjones
  • ronjones's Avatar
Re: Carb Questions
26 Jan 2007 08:31
#108302
:blink: :cheer: :lol: :pinch: :( :unsure: :ohmy: :blush:
  • DemonSpeed
Re: Carb Questions
29 Jan 2007 16:19
#109021
i have the pod filters on it and i have the Vacume lines open would pluggin those lines on the carbs help any? also the carbs never leak when its setting just as soon as i start cranking it they leak....
Re: Carb Questions
29 Jan 2007 16:49
#109031
Please forgive if repeat questions.
Is an in-line fuel filter in place?
What vacuum lines? Are these stock carbs?
Sounds like re-cleaning may be necessary -- float needle/seat area and pilot circuit (fuel and air).
Carb overflow through the overflow spigots results from failure of the float needle properly seating in the base, which thereby allows excess fuel to pass on through into the flow bowls.
Fuel leakage from the float bowl may also result from a damaged float bowl gasket or loose/stripped float bowl screws, but this will be from around the top of the float bowl and not through the overflow spigots.
  • DemonSpeed
Re: Carb Questions
29 Jan 2007 16:59
#109035
there is no inline fuel filters, yes stock carbs (28mm i belive) the vacume lines (nipples) right above the fuel inlet! the floats all spring back up when pushed down...
  • DemonSpeed
Re: Carb Questions
29 Jan 2007 17:00
#109036
Re: Carb Questions
29 Jan 2007 17:30
#109044
The "vacuum lines" are also known as air vent pipes which are supposed to be open and usually have a tube connected running to the underseat area.)
An in-line fuel filter would help assure no additional incoming crud to frustrate the ongoing cleaning process.
Proper cleaning requires carbs being on the work bench.
Considering diy?
  • DemonSpeed
Re: Carb Questions
29 Jan 2007 17:33
#109045
ok cool thanks patton!
What all would you recomend thoroughly cleaning? while they are dissasembled
Re: Carb Questions
29 Jan 2007 18:41
#109065
Please refer to the latest several posts in the following link for some cleaning suggestions believed also applicable to the '74KZ carbs in question.
kzrider.com/component/option,com_joomlab...w/catid,2/id,108600/
Efforts should be concentrated in the float area for now.
