Z1000H Fuel Injection
- Wull777
05 Jan 2007 03:05
I have a 1980 Z1000H(inj). However I'm looking to replace the ECU control box with something more modern.
The original system works but is , at best, very course. Ideally I'd like a modern ECU which will keep the mixture set correctly at all times.
Can anyone point me in the direction of where to find a replacement ?
I know 'Power commanders' aren't available for this age of bike, however I understand there are other systems out there , some which are also programable from a laptop PC..
Any help appreciated !:
Post edited by: Wull777, at: 2007/01/05 06:06
- steell
Re: Z1000H Fuel Injection
05 Jan 2007 04:41
Do a search for posts made by member Dave Sloan, he has a MegaSquirt programmable EFI controller running on a KZ650 fitted with an 810 kit and has posted about it.
Mine's still a work in progress
- pstrbrc
- '81 GPz 1100 project
05 Jan 2007 06:34
Wull777 wrote:
I'm MegaSquirting my '81 GPz, which (if memory seres me correctly) is the same setup.
There are at least three limitations to the hardware of this system (apart from the control unit) that have to be dealt with.
#1. The injector bungs are actually in the head, not on the throttle bodies, and the injector style Kaw used is prone to overheat. The tendency for the injectors to overheat has often been blamed on the location (in the head, not on the throttlebodies) but my research shows that it's the injectors, not the location of them.
[img size=150][/img]
The injector on the right is the style Kaw used, the injector in the middle is the common one. 19# Ford 5.0 injectors are really cheap, and are like the one in the middle. But to use these require the removal of the head and boring the injector bungs out to 17/32.
2. The air flow meter that Kaw used is strictly stone age. MegaSquirt doesn't even require one, so you will have to figure out a new air cleaner setup.
3. Kaw didn't use a real throttle position sensor (that thing on the left end of the throttle bodies is just a "wide open" sensor). Any system you use will need a real TPS.
Everything else is just making it work. But, if you're serious about this, be prepared for what you're getting yourself into. It's not just changing the box.
Post edited by: pstrbrc, at: 2007/01/05 09:36
Any help appreciated !:<br><br>Post edited by: Wull777, at: 2007/01/05 06:06
\'81 GPz 1100 project
Elkhart, Kansas USA
\"Man does not control his own fate. The women in his life do that for him.\" Groucho Marx
Elkhart, Kansas USA
- The Gringo
- ¡Usted no necesita otra motocicleta!
05 Jan 2007 06:43
Wull777 you may want to check out this site for info on upgrading your system. There are several links to other sites you may find helpful.
sid.young.googlepages.com/home
I am curious as to where you are located, your bike was never imported to the US we only got the G-1 for a fuel injected offering.
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- Dave Sloan
05 Jan 2007 14:48
The TPS on my '83 gpz1100 throttlebodies works as the later tps's do and gives a true throttle position and is not just an idle switch.
Sid has one of the first injected Kawas that he is thinking about using MS on but I dont think that he has done it yet.
Z650B2 - Injected
- tnutz
05 Jan 2007 15:58
so is there any injectors that can just replace the old ones without any work to the head???
- tnutz
05 Jan 2007 16:30
i also checked on bike bandit, How the hell do they still sell the brain for the EFI system, i thought kawi didn't make it anymore???
- Mcdroid
- Gone Kwackers
05 Jan 2007 17:13
tnutz wrote:
Bike Bandit will often list parts as being available but when they are ordered, they will email you to let you know they are out-of-stock:blink: I speak from a position of experience...I rarely order from them now as I don't trust them...what they have on their site is not a reflection of the real world
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- tnutz
- pstrbrc
06 Jan 2007 16:06
tnutz wrote:
Not that I could find when I started working on mine. And if you do stick with the stock style injectors you run the risk of cooking them. There is another option, but it also requires work on the head. You can get throttle bodies from an '82 or newer GPz that has the injectors located in the throttle bodies, but you still have to plug the old holes in the head. Or, find a head and throttle bodies from an '82 or newer, bolt them on and be done with it. Not being one to throw away a perfectly good head, I went ahead and bored my injector holes out. It gave me a chance to plug the emissions holes in the cam cover, and made me tear the engine down far enough that I found I needed a new cam chain and tensioner blocks. Come on, it's a 26 year old engine. It prob'ly needs SOMETHING else done to its insides!:pinch:so is there any injectors that can just replace the old ones without any work to the head???
Elkhart, Kansas USA
Elkhart, Kansas USA
- tnutz
06 Jan 2007 23:12
i think this bike is drive it till it dies...then toss on some carbs and a straight pipe...but till the injection dies. just enjoy it.
- Wull777
07 Jan 2007 12:13
Hi Gringo,
I live in Scotland. I understand that there were around 200 Z100H's imported into the UK in 1980/81, so I guess there aren't too many still running as new these days.
