81 GPZ1100 Road Racer
  • Mc Tavish
  • Mc Tavish's Avatar
Re: 81 GPZ1100 Road Racer
10 Dec 2020 15:10
#839759
Yeah, I hope not. I really want the starter clutch from that zr7!
1978 z650C
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
10 Dec 2020 15:16
#839762
This page has some interesting info:
paulritterblog.wordpress.com/zd-early-superbike-iron/
My dad's '74 Z1
'00 ZRX1100
The following user(s) said Thank You: zed_sled
  • zed_sled
  • zed_sled's Avatar Topic Author
10 Dec 2020 19:28
#839775
Hi Mc Tavish, not a problem on the ZR7, it was in NSW though at Hills Motorcycle Wreckers.
I have got parts from them before sent down with no problems at all. Pretty sure it is a 99 model as well.
Thanks to everyone for the input so far, some great advice and ideas have been put forward.
Might take me a few days to digest it all and get a game plan together. Cheers.
The following user(s) said Thank You: Mc Tavish
  • Mc Tavish
10 Dec 2020 19:31
#839776
Thanks for the tip mate.
Cheers.
1978 z650C
  • 750 R1
  • 750 R1's Avatar
11 Dec 2020 00:40
#839783
Mc Tavish wrote: Thanks for the tip mate.
Cheers.
Had it bookmarked for a while...
www.gumtree.com.au/s-ad/seven-hills/moto...-wrecking/1227194174
  • zed_sled
05 Jan 2021 16:17
#841215
Lucked out on a ZRX Swing arm the other day for a good price. I am sure something else will come up soon though.
Getting the frame braced by a very good shop in the next few weeks, I don't trust my welding skills to do it at home....
Found some good engine bits from a ex kwaka land speed racer within a few hundred kays, so it is all slowly coming together.
Hopefully I can get everything sorted for a build within the next 6 months or so.
Really want it sorted by the end of this year at the latest.
This site has been a goldmine for information so far! Hopefully I can add something to it over the course of this build in the near future.
  • 577nitro
  • 577nitro's Avatar
26 Jul 2021 16:06 - 26 Jul 2021 16:09
#852598
Dales rear swing arm is off a ZRX1100, I know I have the same basic setup.   However, there is a company call MotoGPWorks that sells a exact S1 swingarm replica for about $1300.00 bucks.  I found that the ZRX1100 setup is plenty strong enough, and raises the rear about an inch, thus slightly reducing the rake angle. I have about 3500 miles on my zrx1100 swingarm and I can definitively say it makes a huge difference in handling.  I also, at the same time, increased the swingarm pivot bolt to a 20mm using a ZRX rear axle, it fits perfectly.  I believe the last iteration of the twin shocker GPZ/J models frames are pretty dang good handling.  Their biggest issue was the spindly rear swing arm (frame wise) and slop in the bearing to pivot bolt connection.  Goes without saying the forks and rear shocks were lethal in stock form.  I swapped out the rears for a set of zrx1100 KYB's, which are light years ahead of the stockers, the forks were re-worked with  RaceTek springs and gold valve cartridge emulators.  I re-worked the emulators to get a tighter seal and a progressive type high speed valve spring.  I fine tuned the fork oil as well...this made a huge difference.  These old forks have way too large oil passage holes, they require thick heavy oil to actually dampen.  With emulators installed you can actually have high speed and low speed dampening.
JM2C
577Nitro
Last edit: 26 Jul 2021 16:09 by 577nitro. Reason: spelling
  • 577nitro
  • 577nitro's Avatar
05 Nov 2021 10:15
#857454
You can buy lay down bolt on kits from webike.japan.com, no need to bugger up frame.
