Air shifter
- toad
Air shifter
13 May 2016 10:24
Wanted to purchase an airshifter for a 74 z1.It has a 1075 ,cams,smoothbores etc.It goes to the strip once and a while and the fastest it has been is a 11.33 would like to get in the high 10's so any opinions would be great and opinions on which airshifter.
78 kz 1000
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
wiesco 1015
29mm smoothbores
gs1100 swingarm
gsxr rear
- Kray-Z
- I need more power Scotty....
Re: Air shifter
24 Aug 2016 01:23
The Pingel air shifter is a popular choice....going from a one time best 11.33 to consistent 10's is a big step up...what are the cam specs? Head is ported? What size intake valves?
- zukdave
Re: Air shifter
25 Aug 2016 18:22 - 25 Aug 2016 18:25
This is the one I have.
www.spencercycle.com/air-shifter-electri...e-sure-shift-series/
I got the one without kill because I'll be using this to control it set up to auto shift.
www.racedigitaldelay.com/rpm-1067b-bike.php
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 25 Aug 2016 18:25 by zukdave.
- timebomb33
Re: Air shifter
10 Sep 2016 01:19
mre or mps make good kits just make sure you get yours with the dot 1800lb rated tank you wont make it through tech otherwise
I THINK MY POWERBAND BROKE
