extended swing arm , bottle mount
  • kawi810
  • kawi810's Avatar Topic Author
03 Mar 2016 11:21 - 03 Mar 2016 11:30
#713624
some pics of my 810 [IMG]http://i116[URL=http://s1164.photobucket.com/user/kawi810/media/006_zpscm4syt0c.jpg.html][IMG]http://i1164.photobucket.com/albums/q571/kawi810/006_zpscm4syt0c.jpg[/img] 4
[IMG
.photobucket.com/albums/q571/kawi810/002_zpsfj9hapnb.jpg[/IMG][/URL]cc gpz dragbike co2 bottle mount
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
Last edit: 03 Mar 2016 11:30 by kawi810.
  • kawi810
Re: extended swing arm , bottle mount
03 Mar 2016 11:22
#713625
  • kawi810
03 Mar 2016 11:23 - 03 Mar 2016 11:27
#713626
[IMG
lowering links
Last edit: 03 Mar 2016 11:27 by kawi810.
  • kawi810
03 Mar 2016 11:24 - 03 Mar 2016 11:28
#713627
[IMG
rear brake stay
Last edit: 03 Mar 2016 11:28 by kawi810.
  • kawi810
03 Mar 2016 11:26
#713628
  • PLUMMEN
  • PLUMMEN's Avatar
03 Mar 2016 17:19
#713677
It looks good,But Id be worried about something being thrown into top of bottle/valve by the tire going down the road. ;)
  • zukdave
  • zukdave's Avatar
03 Mar 2016 18:53
#713703
My bottle's in the same place but mine doesn't see street time.
Like the arm how long did you go ?
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • kawi810
04 Mar 2016 00:50
#713724
it works out to be 66" wheelbase about 8" on the arm.most dragbikes mount the bottle there .if it is a problem i will make a shield (cover) .
  • zukdave
  • zukdave's Avatar
04 Mar 2016 04:24
#713734
Cool that's just a bit longer then mine at 63" with both being 8" over.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
