Good season start
- turboguzzi
Good season start
16 Apr 2015 08:22
so then, am i still the only member road racing a kawi here?
whatever, the italian vintage championship started last weekend at the Varano track and I brought home a 3rd place trophy on my old & trusty Gpz750/810 behind a full 1000 cc guzzi and duc.
amazingly, motor it still super strong after 4 seasons without much attention, was easily able to stay with a 16 valve, air-oil 750GSXR on the straights in one of the mixed classes practice, so that 90 rwhp was no fluke
cheers,
(i'm the told guy on the right BTW...)
TG
cheers,
TG
- Mcdroid
- Gone Kwackers
Re: Good season start
16 Apr 2015 09:16
Congrats! and thanks for putting a face to an avatar. Some of us do follow you in your posts on KZR.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- zukdave
16 Apr 2015 17:11
TG I may not comment but I do follow your post's about your racing.
Keep adding to this thread like I've done my drag strip thread
and keep it in one place will make it easyer to follow you.
As for racing road or drag very few on here race their KZ's
I guess their too scared of breaking them.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- mopguy
16 Apr 2015 17:18 - 16 Apr 2015 17:20
Auguri!! e Grazie assai per la vostra contribuzione al KZ Rider, da Toronto, Canada.
Last edit: 16 Apr 2015 17:20 by mopguy. Reason: added
- bluezbike
16 Apr 2015 23:31
Sweet start TG......I have never raced but may try one of these days......I follow your and zukdave's exploits, lots of luck to you both.
79 KZ 1000 LTD
- turboguzzi
17 Apr 2015 14:42
tnxs guys
a side note, just for peace of mind took off this week the sump coveroff after four years to have a peek and it's amazing. not even a hit of swarf or metal particles, and i do plenty of clutchless shifting during a race. everything looks just perfect after 4 season of hard racing and shifting at 11K. Neither did the shims require any adjustment and that's with pretty hot cams. I do change oil and filter every other race though.
Dont know the bigger K motors that well , but i am tempted to say that the 650/750 unit is even more bullet proof!
- zukdave
18 Apr 2015 12:22
I think the small four is a better motor with the one piece crank,
plain bearing's, a better oiling system and shim under bucket.
I beat the dog shit out of mine and don't worry about it.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- loudhvx
18 Apr 2015 13:16+1zukdave wrote: I think the small four is a better motor with the one piece crank,
congrats TG!
I think Corey has moved on to SV's, but I wonder if he will still campaign the ZX.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- turboguzzi
20 Apr 2015 15:44zukdave wrote: I think the small four is a better motor with the one piece crank,
zuk, have you ever dynoed the motor? your tune state sounds a lot like mine
- zukdave
20 Apr 2015 16:45
I did back when I put the VM29's on to see the A/F ratio
at 15 to 1 way lean it made 76 hp at the wheel.
Now with the fresh motor and way better jetting I'd say it's
high 80's or better.
I plan on calling the dyno guy this week and see about another dyno day.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- turboguzzi
29 Apr 2015 10:56
hei zuk, lets see waht you get jetted properly
my experience with the 810 kit was that as installed compression ratio was not high enough.
welded the heads quite a bit to get higher CR and larger squish areas.
- zukdave
29 Apr 2015 16:06
TG when I had the head done Curtis took about 020 off the surface
so I'm thinking about 10 1/2 CR. I'd like it to be over 11 to 1 CR.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
