Brakes options
- leitz
Brakes options
04 Jan 2013 16:00 - 13 Jan 2013 07:37
I want to upgrade my Kz650 brakes for track days-vintage festivals and in the future some vintage races in the 70´s 750 class with 2 piston max calipers and 300 max disc diameter rules. Next my house just opened the Ap Racing distributor for Spain and i think is the moment to do it. The guy explain me CP2696 41 mm piston calipers will work perfect with my 5/8 master cilinder. Not cheap. Also seeing other calipers commonly used like Grimeca and Brembo P08 like Turboguzzi uses on his Gpz with Brembo SC pads as i have read somewhere
I have 275 mm discs 5mm thick on bike, 5/8 mc and have no idea where to find fork adaptors for my bike
Wich is the best option: permormance-price-pads-easy fitting?
All suggestions are welcome
Last edit: 13 Jan 2013 07:37 by leitz.
The following user(s) said Thank You: aviliora
- leitz
Re: Brakes options
07 Jan 2013 10:03 - 07 Jan 2013 10:04
Just bought Ap Lockheed 2195 calipers with adapters in good condition. Now i´m looking for a classic master cylinder 5/8 or 16 mm. Ap racing mc cost 540€ in distributor so i will see other options like Brembo.
Some racing bikes with Ap Lockheed calipers:
Attachment 1.jpg not found
Attachment 2.jpg not found
Attachment 3.jpg not found
Attachment 4.jpg not found
Last edit: 07 Jan 2013 10:04 by leitz.
- turboguzzi
Re: Brakes options
11 Jan 2013 07:04
congrats, just dont want to ask how much they cost..... but hey, bling is nice, no?
have no idea what pad compound you will need to run with them, depends if you are running SS discs or cast iron and quite critical if you really race and not just parade.
in italy we are only required to have the reservoir in one piece with the M/C (not separated), plenty of japanese M/C form early 90's are like that in case you dont want to spend.
adaptors to the fork legs are not that hard to do. just cut them by eye first in 10mm plywood, play around and when you reach the right holes location, cut in 10mm Al. Use spacers to bring caliper center line spot on the disk.
- z1kzonly
Re: Brakes options
11 Jan 2013 10:48
I had these 2 calipers on the e bay for 7 days. Only $14.99? No bids. I paid 3 times that a year ago for a project that fizzled out. They probally cost $3-4 hundred at the dealer.
Nothing some 1/4" aluminum plate can't hand fabricate up to use on most anything.
cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&i...ageName=STRK:MESE:IT
- turboguzzi
Re: Brakes options
11 Jan 2013 15:44 - 11 Jan 2013 15:48
Hei z1kzonly, give leitz some credit.....
He races in Spain and in most classes of european vintage racing, double piston (meaning side by side ) calipers like yours are not allowed. Same situation in Italy, that's why i use Brembos P08s
I know AHRMA in the USA allows 17" wheels and modern brakes on older racers but in europe things are different.
Last edit: 11 Jan 2013 15:48 by turboguzzi.
- wireman
Re: Brakes options
11 Jan 2013 23:21Ill give ya $50 for the pairz1kzonly wrote: I had these 2 calipers on the e bay for 7 days. Only $14.99? No bids. I paid 3 times that a year ago for a project that fizzled out. They probally cost $3-4 hundred at the dealer.
- dbsuperbiker
Re: Brakes options
12 Jan 2013 07:22 - 12 Jan 2013 08:00
...AHRMA allows modern rotors, but calipers are restricted to 2 pistons.
for a vintage parade bike on a budget, try the iron 2 piston Triumph T140 calipers...plentiful, cheap, and with a coat of gray paint they look like the antique Lockheed racing version.
Last edit: 12 Jan 2013 08:00 by dbsuperbiker.
- nanno
Re: Brakes options
12 Jan 2013 13:54
Knocking up the plates is really as simple (mine came off a CBR600, but the same Nissins were also fitted to the Bandit 600):
Cheers,
Greg
Cheers,
Greg
- leitz
Re: Brakes options
12 Jan 2013 15:36 - 12 Jan 2013 15:42
I bought a pair of Lockheed 2195 with adapters and 290mm diameter 6mm thick iron discs perfect for the calipers. All really cheap, i think the man who sold it never heard about these calipers.
Also i´ve order on ebay Ebc HH pads but i´m not sure if they are compatible with iron discs. Maybe I try on track with Ferodo CP1 (new Cp211 compound) but not know how they work in these old bikes. I may not need more than HH... don´t know which pads are generally used on vintage racing.
Attachment 1-copia-copia.JPG not found
Last edit: 12 Jan 2013 15:42 by leitz.
- z1kzonly
Re: Brakes options
12 Jan 2013 18:13Thank You Wireman! We have a deal!wireman wrote:Ill give ya $50 for the pairz1kzonly wrote: I had these 2 calipers on the e bay for 7 days. Only $14.99? No bids. I paid 3 times that a year ago for a project that fizzled out. They probally cost $3-4 hundred at the dealer.
I'll type to ya soon.
Marty
- turboguzzi
Re: Brakes options
14 Jan 2013 14:55leitz wrote: I bought a pair of Lockheed 2195 with adapters and 290mm diameter 6mm thick iron discs perfect for the calipers. All really cheap, i think the man who sold it never heard about these calipers.
looks like a very nice setup, and if you got them for cheap, then i am jealous!
in my experience, the new ferodo CP pads likes cast iron, hates SS, so you're good. just dont assume that the first M/C you try will work, you might have to try a few sizes till you find the right leverage ratio/power/feel.
having consistent braking power lap after alp into a race is really important, take your time to look for the right setup/pads. some circuits are so hard on brakes that its almost impossible to find a solution.
- leitz
Re: Brakes options
15 Jan 2013 10:04 - 18 Jan 2013 15:30
Good to know. Thanks for your replies guys
Like wrote Turboguzzi those Tokico aren´t allowed but I'm not entirely sure. Anyway they are for sure a big improvement for the originals
Can anybody identify this 290mm disc? it´s an aftermarket part? (i think white area have been painted by the previous owner)
Attachment DSC01251.JPG not found
Last edit: 18 Jan 2013 15:30 by leitz.
