- Thank you received: 229
Drag strip trip.
- zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
- zukdave
So yesterday morning with us having rain in the forecast I checked the track website and the race was still a go
so we loaded up drive the hous or so to the track get there gates locked so check the website and they called the race while we were
on the road.
Pretty bummed out was really looking forward to having the boy at the track with me for the first and he was excited
as hell to be there but it is what it is.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
Been playing with timing curves and bike's leaving and pulling the first three gears harder then it ever has
on the street so maybe I can get that first 6 sec. pass.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- KZB2 650
- Thank you received: 265
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- zukdave
KZB2 650 wrote: 11.20s your so close ..... were rooting for ya.
If I remember right the Denco KZ650 back in late 70's was said to be the fastest KZ650 in the country
at 10.86. with a slick and a wheelie bar.
My goal is beat those number's no bar DOT street tire and still keep a legal tag and still street ride it
hell I was gonna ride it 50 mile round trip for a bike night last night and it f'in rained.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
to start from scratch so started at the pickup coil's found they were a little out of sink with each other fix'd that then
set it at 5 degrees base timing the Dyna 2000 will only let me add 34 degrees to the base timing .
Loaded a few new timing curves we'll see what happen's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- Thank you received: 2744
- zukdave
and see if it helped. Dropped the temp 10 degree's in about 30 min. and let me close the door's the afternoon sun icomes in my door's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
and it's f%^&n HOT.
I think at this point without a modern set of carbs and some good cams I'm not going to go any quicker the bike just doesn't
run the mph I think it should. Right now there isn't the money to do cams and carbs
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
