Drag strip trip.
Re: Drag strip trip.
05 Sep 2016 13:06
The pics loaded but the clip didn't.
Was sent a link to a new track near me. I don't know if they have a 1/4 mile though.
goracecvr.com/
goracecvr.com/
- zukdave
07 Sep 2016 01:20
Worked for me but try this.
I messed with it some more last night it's shifting the 1-2 shift but will make the next shift so I'll call D/D today
and see what they say.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
09 Sep 2016 04:39
I Found what I was doing wrong in the setup programming it work's now.
In this step I read it as I need to set it for 1,2,3,4 shift's but turns out setting it for
one of those it turned OFF the ign. kill those settings are for if you have a auto shift tranny.
For those that don't know there is a mod. you can do to a lot of bike tranny's that will make it
auto shift but you CAN NOT compression brake while in one of the auto shift gear's.
[/URL
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
09 Sep 2016 09:29 - 09 Sep 2016 09:29
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 09 Sep 2016 09:29 by zukdave.
- KZB2 650
09 Sep 2016 11:28
I love the smell of rubber and goose bumps up and down my spine in the morning.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- zukdave
11 Sep 2016 18:09
Little update since I got the box working right I've been able to play with the rpm setting's and kill time's
and right now a 9500 rpm 1-2 shift feel's like the Astro van pulling off from a red light doing the 1-2 shift.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- KZB2 650
12 Sep 2016 07:56
Why not a shift point at 10,500 or a little higher? My stock 750 cams are red lined at 9,500 but I thought with the GPZ cams its more like 10,500 +.
1978 KZ650 b-2
- zukdave
12 Sep 2016 16:10
For one I was on the street and two factory red line is 9800 if I remember right.
I have foot shifted at 11,500 but with stock cams there's no reason to turn it that hard.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
26 Sep 2016 22:53
Looks like Revivalcycle's here in Austin that puts on the Handbuilt show is going to have a race at little River
for the vintage/cafe bike's. Think I'll show up with my little 650 and see if I can hurt a few feeling's. :evil: :evil:
revivalcycles.com/blogs/the-twist-off-media
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
25 Oct 2016 15:39
Well what started as a simple valve adjustment and compression test turned in to the top end coming off.
Intake's where .004, .005, .004, .004.
Exh. where .003, 003, .003, .007
Did the comp. check and cyl. four was 30 psi lower then the other's so pulled it apart
and found #4 intake valve not seating right so I'll relap all the valve's and see what the seat's look like.
Cylinder's and piston's look like they have never been ran other then some carbon on the domes.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
25 Oct 2016 15:53
Bummer.
A little oil getting past the rings?
- bluej58
26 Oct 2016 06:37zukdave wrote: Looks like Revivalcycle's here in Austin that puts on the Handbuilt show is going to have a race at little River
Good Luck
78 KZ1000 A2A
