- Thank you received: 47
Drag strip trip.
- BlackZ1R
- Kawasaki in my blood
29 Aug 2012 18:17 #545520
by BlackZ1R
Kawasaki
Someone once told me to marry that motorcycle I was riding ......there's times I wish I hadda listened .
Replied by BlackZ1R on topic Drag strip trip.
That's pretty impressive time slips Dave. Keep us posted on your rear swinger upgrade.
Like wireman says, one it starts hooking keep a closer eye on the drive train.
I'm digging Little River Dragway :woohoo:
Kawasaki
- zukdave
- Thank you received: 229
31 Aug 2012 12:50 #545881
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Replied by zukdave on topic Drag strip trip.
Well off to the track again.
See if I can ride this thing and keep from blowin the tire off.
Update on Monday as we're campin all weekend and watchin
the nitro bike's play.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- Mark Wing
31 Aug 2012 18:10 - 31 Aug 2012 18:10 #545930
by Mark Wing
Yorba Linda Cal.
Replied by Mark Wing on topic Drag strip trip.
Have FUN, looking forward to some numbers.
Mark
Mark
Yorba Linda Cal.
Last edit: 31 Aug 2012 18:10 by Mark Wing.
- 4TheKZ1000
- Visitor
31 Aug 2012 21:11 - 31 Aug 2012 21:27 #545950
by 4TheKZ1000
Replied by 4TheKZ1000 on topic Drag strip trip.
I like the first 2 pics....there’s just something about the bike that says "tough" I bet if you take a pic of the rear it has a set of balls.....love to see the KZ at the track....It still transforms time and is still relevant
Last edit: 31 Aug 2012 21:27 by 4TheKZ1000.
- timebomb33
- Thank you received: 10
01 Sep 2012 04:47 #546004
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Drag strip trip.
i used that exact same swingarm on a 1015 motored 5 inch slick dragbike it worked great what i did for the strut mounts was i cut of the single shock linkage mounts off the swingarm and flipped them around and figured out where they had to be to keep the frame and swingarm parrelel and the welded them up on the top of the swing arm it worked awesome. i rode that bike like that for about 10 years got down into the 10.20 range always went straight. the only problem i had was when i change the chain tension it would change the wheelie bar heights so you have to keep an eye on that because of the eccentric adjusters. i also set it up for drum brakes as the frame was a 74 z1. i used a 3.5 inch sun rim and buchanens 8 gauge stainless spokes never had a problem with them breaking or loosening up every time i changed tires i would check the tension. don't go to a 17" inch becuse you won't be able to get slicks when you want to go to one.the only 17" slick available right now is either the mickey thompson or the shinko reactor but they are 7" tires so way to big for your bike. so what i'm saying long and short is stay with a 5" tire if you can. the street tire is fine to begin with but down the road you will definitly want the traction a slick will give you. no matter which way you go have a blast.
- zukdave
04 Sep 2012 23:52 #546731
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Update!!
Went 12.12@105.93 with a 1.76 60 foot.
Still fightin the tire spin but the longer arm sure may'd a diff.
If I bring the rpm's up were the motor like's to launch I
have to slide the clutch out way to long
drop the rpm's so it don't blow the tire off it go's to slow.
Timebomb I started to do the same thing with the same mount's
but for me they hung off the arm to much and just
looked ugly.
As for the tire later in the week I gonna go
look at a 4.25X18 Akront rim and a 5.5 slick.
If the money's right I'll get them.
looked ugly.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- lushbaugh
- everybodys a pro......
- Thank you received: 35
06 Sep 2012 17:09 #547096
by lushbaugh
79 kz1000 ltd all apart
the best advice i can give is dont take dnthavakawmans advice..
Replied by lushbaugh on topic Drag strip trip.
what seat is that and will it fit my 1000? and i have one of those motors sitting around if you need parts lmk, it has jb weld on the case around the stator cover, thats all thats wrong with it.
- zukdave
06 Sep 2012 22:54 #547175
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Lush the seat was on the bike when I got it
Best I can tell it's 1000 seat pan that's been recovered
as its a little wide for my 650 frame.
I'll take some pic of the factory sticker's
on the pan maybe some one can ID it.
Talk to me on the motor I need an 83 model head to send
to Larry C and not take my motor apart till it get's back.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- lushbaugh
08 Sep 2012 20:45 #547534
by lushbaugh
Ok ill check when im at my dads, its a kz 750 motor is that what ya need? If ya got a cell number send it to me and ill shoot pics and if ya want it ill pull it off
- zukdave
13 Sep 2012 00:23 #548390
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
I need a gpz head not the kz head but thank's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- ramtough_63
13 Sep 2012 00:29 #548393
by ramtough_63
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
Replied by ramtough_63 on topic Drag strip trip.
I;ve got a complete running 82 750R motor has the 83 gpz badging all over it is in an 83 frame
I dont know the difference between em it may be available if My buddy doesnt need it
1978 KZ1000 A2
Facebook Page
1982/83 750R/GPZ
Previous
2 79 HD sporty XLH
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
- Powerstroke_fan
- Thank you received: 83
13 Sep 2012 20:27 #548522
by Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
Replied by Powerstroke_fan on topic Drag strip trip.
I have a 81 kz 750 complete head. The engine is still together but if your intrested i can get rid of it. let me know.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
