Drag strip trip.
- zukdave
Re: Drag strip trip.
01 Mar 2016 13:58
The GPz arm was 2 1/2" longer than the 650 arm and I added 5 1/2" to it for a total of 8" over stock.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
01 Mar 2016 14:48
Reworked the shock setup a little.
Swapped the shock's side to side that fixed some clearance issue's at the top
then made some diff. lower plate's and moved the bolt hole's a little and now have plenty
of clearance at both end's. Still need to make a new brake stay arm so just stuck that plate
in to mock it up.
Had to whip up a new chain guard since there ain't a lot of room now.
in to mock it up.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
02 Mar 2016 18:39
Messed with the Dyna some after work today playing with diff rpm setting's
for the shift and ign. kill With the two adjustable output's I'm using one to trigger the air shift
the other trigger's a relay that cut's power to the coil's as a way to kill the ign. on the shift.
I turned the shift down to 3500 to make it easier to test ride
and played around moving the kill rpm's up/dn a few hundred rpm's and also added more
rpm's between on and off rpm's and learn a little more about how to make this shit work
the way I want.
Then I got low on air in my refill tank and couldn't refill the bike tank so with not enough air for it to shift right
I put it up and had a beer.
the way I want.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
04 Mar 2016 19:13
Track day tomorrow going to go do some test pass's and see how the shock setup work's.
I've not rode it over 15 mph with the shock's so this might be fun.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- undiablo
05 Mar 2016 05:48
Awesome bike!
Does it has multi spark?
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
- kawi810
05 Mar 2016 19:12
ok did the shocks help?
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
- zukdave
05 Mar 2016 19:17
Not sure I got to make one pass today.
I'll post the story later I'm tired.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- kawi810
05 Mar 2016 19:22
ok time to drink some busch and par take . you will figure it tomorow.
- zukdave
08 Mar 2016 04:38
A damn relay took a dump and shut power off to half the bike
simple fix but by then it was about 4:30 and they said next
tnt pass's would be after first round of elimination so about two hour's
so just packed up and went home.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
15 Mar 2016 18:26 - 15 Mar 2016 18:34
Back story leading up to the relay deal.
So get to the track about 11:45 am. Pit spot I like under the big tree is open
so park and and get unloaded.
Get the genny and air comp. set up and then rode the bike to the tech booth
to turn in my card and then back to camp.
And waited and waited and waited finely got to make a pass at 3:45 pm.
Any way's go make an easy pass to get a feel of the bike do a soft launch
(1.82 60ft time)and run 80 mph for a shake down pass I wanted to see what raising the rear did
to the front at speed and it all felt good so go right back to make a hammer on it pass
get the light launch it bog's then come's alive and then shuts the F$%^ off at the 30ft.
and for the first time since I started this shit I pushed the bike back off the starting line.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 15 Mar 2016 18:34 by zukdave.
15 Mar 2016 18:47
CRAP :dry: Next weekend?
- zukdave
15 Mar 2016 19:14
Nope first race in the Motorcycle mayhem series is this Saturday and
it's my month to work Saturday's so I might miss this one.
They're running it same day the car's run but if they run the bike's that night
after the car's I could make it.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
