- Thank you received: 229
Drag strip trip.
- zukdave
and at wide open throttle it's working great..
Tomorrow I'm gonna check the output voltage on the tach for the shift light
and see if I can use it to trigger the shifter relay.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
- Thank you received: 2062
- z1kzonly
- Thank you received: 540
Craigslist in Buffalo, NY
buffalo.craigslist.org/mcy/5339276562.html
- zukdave
3 1/2 tenth's quicker but only one mph faster. don't sound right.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
and use's a ground signal to turn the light on so swapped some wires around
but couldn't get it to work right kept blowing the ign. fuse it'd shift one time and pop the fuse.
I'm thinking it has to do with the way I've got the two relays tied together with one
applying 12 volt pos. and the other applying a ground so just put it back like it worked
and I'll just button shift it off the light tomorrow.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- rstnick
- Thank you received: 377
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- zukdave
rstnick wrote: Happy racing Dave.
Not today looks like I just can't ride this thing on two wheels.
Launching with my chin on the tach, tits on the tank, feet behind the bike flappin
like a baggy in the wind,and sliding the clutch 40 feet out this damn thing still wants to ride wheelies.
I give up I'm going back to the bar.
I just got home I'll do a race report in the morning.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
staging lanes and it wouldn't restart when warm. Push start and make a pass
get back to my pit let it sit and cool down it'd fire up then not restart in the staging lanes.
I get back to my shop taht night bike still won't start when I unloaded it go back Sunday morning
to finish unloading the van flip the switch on hit the start button motor turns over about two times and
fires up no problem F'in battery.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- Thank you received: 2744
- zukdave
and I got put out by 2.4 tenths. I could have bought back in but said F$%k it I'm not gonna take the chance of cookin
my motor and drank beer..
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- z1kzonly
At least you are there! That's what it is all about. You'll get it dialed in. You will be all set next season.
Keep at it! I've been there. I have not been on a drag bike at a strip in about 15 years! I miss the hell out of it!
