- Thank you received: 2744
Drag strip trip.
20 Nov 2015 16:15 #699670
by SWest
Replied by SWest on topic Drag strip trip.
Anti virus software?
- zukdave
- Thank you received: 229
21 Nov 2015 02:32 #699705
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Replied by zukdave on topic Drag strip trip.
Programming software for my Dyna 2000 ign. so I can set it up
to auto shift the air shifter.
Air shifter kit should be here today when the mail runs.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
23 Nov 2015 02:33 #700067
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Got the software to load but my air shifter didn't show up yet.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
23 Nov 2015 16:23 #700189
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Air shifter showed up this morning and since the kit I got didn't come with a tank mount
I used some 5/16 rod and started on a mount.
Now I need to make the ign. box talk to the shifter.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
23 Nov 2015 16:25 #700192
by SWest
Impressive.
- pete greek1
- Thank you received: 185
24 Nov 2015 07:34 #700293
by pete greek1
Replied by pete greek1 on topic Drag strip trip.
Cant wait to hear how the brain & shifter work together
Pete
Pete
- zukdave
24 Nov 2015 15:53 #700370
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
My POS laptop is not playing nice loading the software
The curve maker that lets me plot my own advance curves works
the rpm window switchs work but its not letting me find the ign. kill settings.
Gonna take the bike to my work Sat .and do the air shifter install
thats were the welder is. to do mount's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
28 Nov 2015 11:40 #700963
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Man it was cold (39 f.) and wet riding to work this morning good thing my little
shops only about four blocks away.
Made frame and shift lever mounts and got the ram mounted.
Finished the bottle mount and ran the air lines now need to do the wiring and
get the software working but a test run jumping the wires it shifts great.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- riturbo
- Thank you received: 280
30 Nov 2015 14:02 #701266
by riturbo
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
Replied by riturbo on topic Drag strip trip.
Looks good dave .
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
- zukdave
30 Nov 2015 14:36 #701269
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Thanks ! Looks like I'm gonna need to replace my POS laptop
to get the software to work right but need to anyways.
Testing it on the rear stand unloaded it shifts great but without the ign. kill
it ain't gonna shift right under a full throttle load.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
30 Nov 2015 14:46 #701270
by SWest
Whatever you do, don't buy a HP lap top. I hate my new one.
- zukdave
02 Dec 2015 15:37 #701629
by zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
We be button shiftin tonight
Got the air shifter wired tonight I used one relay to trigger the
shifter off a thumb button then a second relay to ground the wire for the
the side stand inter lock to kill the ign. till I can fix my puter issue's.
but on the little test ride's I did it's shifting like it should under load..
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
