Drag strip trip.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Drag strip trip.
31 Oct 2015 03:40
#696604
I'd like to see how you do in the 1/4.
The following user(s) said Thank You: KZB2 650
  • zukdave
  • zukdave's Avatar Topic Author
12 Nov 2015 14:45
#698380
Makeup race is Sat. Dec. 5th so I guess I need to do an oil change,
swap rear sprocket, battery on the tender then wash it.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
  • gpz1170
  • gpz1170's Avatar
12 Nov 2015 15:04
#698383
I'm jealous
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
  • SWest
  • SWest's Avatar
  • 10 22 2014
12 Nov 2015 15:14
#698385
Pics and maybe a clip or two? :)
  • zukdave
13 Nov 2015 13:40
#698523
Steve its hard to pic as most trips its just Vickie and me
and with her health issues she can't spend much time out in the heat and sunbut we're turning cooler so that'll help.
Ordered the air shifter setup and the software kit for dyna 2000 box. today
should be here mid. week.
Auto shift here I come :woohoo: :woohoo:
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • SWest
  • SWest's Avatar
  • 10 22 2014
13 Nov 2015 15:30
#698533
Right on, I won a clutch cover that had the actuator in it. It's in excelent shape. I'm going to follow your lead and extend the arm 1/4". Should make the pull easier and maybe the cables will last longer.
  • zukdave
13 Nov 2015 16:52
#698551
I see no reason making the arm longer would not work in your motor
other then some side load on the inner cable coming out of the adjuster in the case.
With my cable end on a bracket out side the motor I can bend it and aim the cable straight
but with yours being fixed in the cover you can't do that.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • pete greek1
  • pete greek1's Avatar
14 Nov 2015 09:15
#698623
P.S. I'm still waiting to see some pics. of your Pit Bike/Trike with the bed painted in your Pit Bike Thread, :whistle:
Pete
  • SWest
  • SWest's Avatar
  • 10 22 2014
14 Nov 2015 11:03
#698631
zukdave wrote: I see no reason making the arm longer would not work in your motor
I'll keep that in mind while I have it off. If it doesn't work I'll still have a polished cover and a new worm casing. The KZ 900 cable holder is slightly longer than the Z1. I had to adjust for the slack caused by it. Maybe I'll keep it and use the KZ one for this experiment. They're both steel.
  • zukdave
14 Nov 2015 13:10
#698644
pete greek1 wrote: P.S. I'm still waiting to see some pics. of your Pit Bike/Trike with the bed painted in your Pit Bike Thread, :whistle:
Pete
Me too :laugh: :laugh:
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • zukdave
16 Nov 2015 15:43
#699008
Thinking I need to check valve clearance so thinking I'm gonna swap the
exh. cam for the spare intake cam I've got while I'm in there.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • zukdave
20 Nov 2015 15:51
#699669
Got the software kit the other day and for some reason it will
not load on my laptop I've tried from the disk and from Dyna's website
talked to tech support about seven times and still won't work.
From Dyna's site I can down load the software for the 2000SE model
with no issue but not the 2000 stuff. the install wizard loads then it stops loading.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
