- Thank you received: 229
Drag strip trip.
- zukdave
The pull at the lever is a lot lighter and now have two times
as much useful travel at the lever.
Whipped up this little plate to bolt to the arm as a test piece.
Turned out the little plate worked better flipped over.
I'm going to run it bolted on for the next race and see how it works then I'll
cut and weld it and get rid of the bolts.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
- Thank you received: 2744
- zukdave
you'd be better off doing a hydro clutch setup.
Anyways bikes ready weather chick says it's gonna be hot
but dry this weekend and I ain't got a damn thing to do but wait till Sat. morning
and load the campin gear.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Have a blast out there and put up some pics. At least I can see what's going on out there. :evil:
- zukdave
one to fall back on.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- DSummerlin
- Thank you received: 10
78 KZ650
82 KZ1000 LTD
99 ZRX 1100
- zukdave
and do some testing then drink beer and maybe fire up the grill.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
swest wrote: Sounds like a blast.
That start's in the moring.I'm a wake up away from loadin shit
and spenting the weekend at the track..
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
it did great towing the trailer with the bike, the trike and
all the campin gear about 1200 lbs total and got a little over 25 mpg's.
Setting up camp for the weekend.
Knowing it was gonna be a hot weekend I got my cool on.
With no headliner I knew it be hard to cool so used some blue foam board and did the roof.
Even with the slide door open all day by dark it was sweatin the outside of the window's.
Queensize air mattress fit's perfect in the back. Even at 90+ degress with the slide open all night Vickie still
needed a sleepin bag to cover up.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
