- Thank you received: 229
Drag strip trip.
- zukdave
and the stud's installed, the 650 sump swapped
and the ring end gap's done and installed on the piston's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
- zukdave
I get with new air filter's at work and cut some strip's out of a 2 liter
pepsi bottle to rap around the piston's to protect the ring's.
and use as ring compresser's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
Also having 020 shaved off so that should put the C/R just under 11 to 1.
Next up is deal with the clutch,
Partszilla list the OEM fiber plate's as a good number
so should get them and some APE clutch springs next payday.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
so I'll go get it after work tomorow.
Started making some valve cover block off plate's
and new motor mount plate's.
I guess the cheapie northern tool drill didn't like the hole saw's 3/4 ways through
the last hole all the smoke came out.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- z1kzonly
- Thank you received: 540
I do the same. Take 2-3-4 hours time to make 1 part. Because I did not pay the man!
Good Luck with the re-build!
- zukdave
this bike since I got it. only thing I didn't do was weld
the swing arm.
In the last six weeks I spent damn near as much money on the
motor as I have in the bike itself..
Right now I'm just under $3500 total on this bike
counting buying it and stand a good chance of going in the 10.00's
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- zukdave
bike this weekend.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- racer54
- Thank you received: 114
- z1kzonly
The good Ol' days. Mike Bruso wheelie bars with a Denco left exit headerracer54 wrote: Tony Nicosia 11.23 @ 115.85 mph
- racer54
- zukdave
Ya know I guess I'm hard headed cause I could just built a
KZ1000 and go way faster for cheap money there's part's fallin out
of the tree's for them..
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- racer54
