Drag strip trip.
  • donthaveakawman
  • Visitor
12 Feb 2013 21:18 #572155 by donthaveakawman
Replied by donthaveakawman on topic Drag strip trip.
do you have a parts getter' bike?
12 Feb 2013 23:22 #572172 by 821000ltd
Replied by 821000ltd on topic Drag strip trip.
In the 2012 NHRA rule book Section 4C page 14, you will find that wheelie bars are OPTIONAL.
If you do choose to run a wheelie bar the "Maximum length may be equal to, but not exceed
the wheel base of the motorcycle. Wheelie bar length is measured from the center of the rear
axle to the center of wheelie bar wheel
82 KZ1000 LTD
Kerker 4 to 1
80 KZ 250
23 Feb 2013 21:57 #573776 by zukdave
Replied by zukdave on topic Drag strip trip.
So when I built my last bar I used
3/4x120 wall tube as I had it on hand
but it's heavy IMHO.
Went to get some tube this morning
and all they had was 3/4x.120 DOM at about $75 buck's
and just as heavy or 3/4x.060 in a welded seam
for about a buck a foot.
So question for those in the know you think
the .060 wall would be strong enough ?
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
24 Feb 2013 07:12 #573847 by Lorcan
Replied by Lorcan on topic Drag strip trip.
zukdave wrote: I think if I can get it to stop spinin the tire through the 60 ft. it should go 12.20s or better
just need to work on the tune and set up some more.
Have you ever run it with shocks and no bar? My 60" no-bar bike used to run mid 1.5s in the sixty.
760cc - 8.69@162mph
810cc, 211mph www.750turbo.com
www.stormdragbike.com
24 Feb 2013 09:36 - 24 Feb 2013 09:57 #573855 by Old Man Rock
Replied by Old Man Rock on topic Drag strip trip.
"My 60" no-bar bike used to run mid 1.5s in the sixty. "
Jesus Lor, talk about acceleration ass-pucker factor :blink: .... I'd crap all over myself :blush: that's insane and here I thought my little build was fast (well enough for me anyways)... Ah well, I guess I should get a supply of new skivies with the build I'm doing now...
Keep at her Dave, post the results, LUV it! B)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 24 Feb 2013 09:57 by Old Man Rock.
24 Feb 2013 11:47 - 24 Feb 2013 11:59 #573869 by zukdave
Lorcan I've gone 12.12 @ 105,93 with a 1.71 60 ft no bar with the strut's
stock rim on a 130mm Dunlop spinnig about 50 ft. out.
I haven't ran the bar with the longer swing arm and the 3.5" wide rim
but right now it want's to wheelie bad when/if it hooks up.
With the street tire I never know what it's gonna do
some time's it hook's and some time's it spin's it a$$ off
so I'm working on putting a slick on it and will need the bar again.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Last edit: 24 Feb 2013 11:59 by zukdave.
24 Feb 2013 11:51 #573871 by les holt
Replied by les holt on topic Drag strip trip.
Michelin Power One, that will hook! Ryan Schnitz went 6.90 at 204 mph on it with no bar. Buddy of mine running it on his turbo busa, 70" wheel base run 7.13 at 199 mph, 60's in the mid 1.3's. I went to it and it's better than the shinko.
Les
24 Feb 2013 12:02 #573873 by zukdave
Les no one make's a sticky tire for an
18" rim that I can find other then a slick.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
24 Feb 2013 12:10 #573874 by les holt
03 Mar 2013 22:37 #575161 by zukdave
Got a little done on the new bar Friday night.
Then later in the night the G/F decided to
break a bunch of bone's in her right foot
so that f@@ked my weekend all up.
Guess I'm having wheelie bar for lunch at work
for a few day's.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
  • 4TheKZ1000
  • Visitor
03 Mar 2013 22:39 #575162 by 4TheKZ1000
Replied by 4TheKZ1000 on topic Drag strip trip.
YIKES..... :sick:
05 Mar 2013 23:46 #575552 by zukdave
I got the lower bar's and axle welded up and the
tab's for the upper links made.
Should get them on welded at lunch tomorrow
then double check my upper link measurement's
and weld them up.
I'll get some pic. tomorrow.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
