wanted: GPZ red plastic starter button
  • ajh
  • ajh's Avatar Topic Author
12 Oct 2026 13:19 - 13 Oct 2026 08:09
#928504
Hi, Anyone help me out and got a scrap GPZ right hand handlebar switch to sell/part out. I only need the red plastic starter button as annoyingly mine fell off somewhere last week. (See pic)
thanks
(Im in the UK)
1981 GPZ1100b1, 1986 xl600rm, 1981 RD350LC, 1980 DT175mx, 1982 GS550ez
Last edit: 13 Oct 2026 08:09 by ajh. Reason: more info
  • H1Vindicator
  • H1Vindicator's Avatar
Re: wanted: GPZ red plastic starter button
13 Oct 2026 06:48 - 13 Oct 2026 06:48
#928519
if nobody can spare the button. on ebaayy the cheapest control switch with the same* button I saw is from a zn700. ~$31T but has make offer tab.
eb item number >> 327395127694
* - looks the same. not sure if it is, though.
Last edit: 13 Oct 2026 06:48 by H1Vindicator.
The following user(s) said Thank You: ajh
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
13 Oct 2026 16:01
#928529
Greetings AJH...do you know if the right-hand switch gear (and the button) differ between the 1981 and 1982 GPZ1100  year models? The reason I ask, is that I have a right-hand switch but am unsure what year I have.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • H1Vindicator
14 Oct 2026 05:45 - 14 Oct 2026 05:46
#928532
button looks the same if ebaayy part 178477391155 is correct. listed as an 81 with the 81 part number. 46091-1155. 82 = 46091-1214.
Last edit: 14 Oct 2026 05:46 by H1Vindicator.
The following user(s) said Thank You: Mcdroid, ajh
  • ajh
14 Oct 2026 11:01
#928536
thanks for the reply, I believe they're the same but looks like youre in the U.S and Im in the UK so probably not cost effective just for a button.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
14 Oct 2026 11:49
#928537
I will have a look in the next couple of days, I think it may be the same as my 82 Ltd, if so it's yours. Are you still at the Chiswick address I sent the R/R to ?
  • ajh
15 Oct 2026 09:50 - 15 Oct 2026 09:50
#928550
Thanks, much appreciated and yes still at the same address
Cheers
A
Last edit: 15 Oct 2026 09:50 by ajh.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
15 Oct 2026 10:22
#928551
Looks like your lucky day, just drop a small donation in the forum and I will pop it in the post
  • ajh
16 Oct 2026 12:54
#928565
Result! Thanks thats sooo good of you.
Just made a donation
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
19 Oct 2026 01:25
#928601
It's gone in the post 1st class today so should be with you in a couple of days
  • ajh
22 Oct 2026 00:17
#928621
Received thanks!
