Kawasaki 5/8 Master Cylinder
- asphalt900
21 Jun 2026 05:32 - 22 Jun 2026 03:23
In search of a Nice ORIGINAL Tokico 5/8' front master cylinder with the "tall" plastic reservoir. Unique because used only one year on the dual disc equipped KZ1000/650 bikes. I know various Euro bikes came these as standard equipment too. PM if wanting to sell/trade. Thanks, Clay
Last edit: 22 Jun 2026 03:23 by asphalt900.
- moizeau
Re: Kawasaki 5/8 Master Cylinder
21 Jun 2026 07:59
Have you got a picture of the one you're after?
- asphalt900
22 Jun 2026 01:16
Found one moizeau! Don't have one so found a couple 1977 LTD KZ1000 photos
that used it because of the dual front disc arrangement. Also used on the 1977 KZ650 C1 with dual disc. A ONE year only Master for 1977 LTD's. Also included a "similar" looking at first glance photo of the 1/2" version but note that white plastic reservoir isn't as tall.
- moizeau
- rstnick
22 Jun 2026 18:32 - 22 Jun 2026 18:33
1977 650 C models may have used the same MC, but later years went to the trapazoid/rectangular resevoir.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 22 Jun 2026 18:33 by rstnick.
- Injected
23 Jun 2026 10:35
The 1977 C1 KZ650 came stock with that tall master. Here is the picture from the dealers brochure :
I have one but need it for a restoration on a C1, but I may have a spare in a box somewhere and will have a look. On some bikes I have already replaced those old 5/8" masters for more modern Kawi versions so the chance of me having a spare is pretty high.
1978 KZ650B2 modified project
- asphalt900
24 Jun 2026 01:35
Thank-You Injected! That would be groovy if you happen to stumble across one! Oink has one on ebay but its reservoir is less then desirable.
- limitfish
24 Jun 2026 06:21 - 24 Jun 2026 06:26
Injected, asphalt started this add on my behalf as I don’t always frequent this site. If you have an extra master cylinder that would be fantastic! I recently purchased a very complete 77 KZ650 C1 that the master cylinder has been swapped out for a later model trapezoid type. Let me know what you come up with. Thanks again
I will post some pictures later today
1977 KZ650 B1 (X2)
1979 KZ650 B3
1977 KZ650 C1
1976 LTD 900
1975 H1
1984 ZX750 Turbo (GPZ)
1975 S1
1977 KE250
1979 KZ650 B3
1977 KZ650 C1
1976 LTD 900
1975 H1
1975 S1
1977 KE250
Last edit: 24 Jun 2026 06:26 by limitfish.
- moizeau
25 Jun 2026 04:34
- asphalt900
25 Jun 2026 06:36
Nice catch moizeau!! I was going to mention that because the early GL1000's had pretty much same master Tokico. They had slightly different bracketry/plate underneath the pivot bolt though. I used to work on a lot of the GL1000/1100/1200 and 1500's plus a glob of other similar Honda various CC displacements. I'll wander the web and see. Thank-You!!
25 Jun 2026 06:49Hey Clay there are a few Honda units in Europe but not cheap (by the time you add shipping etc you will be around $250) the below is in California and doesn't look bad (levers been butchered) at a reasonable priceNice catch moizeau!! I was going to mention that because the early GL1000's had pretty much same master Tokico. They had slightly different bracketry/plate underneath the pivot bolt though. I used to work on a lot of the GL1000/1100/1200 and 1500's plus a glob of other similar Honda various CC displacements. I'll wander the web and see. Thank-You!!
1978 Honda GL1000 GL 1000 Front Brake Master Cylinder Lever 45500-431-671 *CORE* | eBay UK
- moizeau
25 Jun 2026 07:08
The one I posted is on Leboncoin dot fr and it up for sale at 15€
