1977-1978 KZ 1000 fuel tank - No longer required
- Kofla
02 Jan 2026 08:49 - 02 Jan 2026 08:59
How much should I expect to pay for a 1977-1978 KZ 1000 (not the LTD type) used fuel tank with no major dents, and still with the little brackets for tank emblems? Z1 Enterprises sells replica fuel tanks, but the prices just went up.
1978 Kawasaki KZ1000 LTD
2010 Kawasaki Ninja ZX-14
Last edit: 02 Jan 2026 08:59 by Kofla.
- StreetfighterKz
Re: 1977-1978 KZ 1000 fuel tank
02 Jan 2026 10:50
If you’re patient, you can probably get one for $150-200. Remember, the 77 and 78 did not share the same fuel tap design if that matters.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: Kofla
- Kofla
02 Jan 2026 12:33
Thank you for your reply. I am not too concerned about the fuel tap design, and I am not in a hurry. The bike will not be completed any time soon. Thanks.
- asphalt900
03 Jan 2026 04:57
I've a 1978A KZ1000 tank but Where are You located? I'm in Kansas. Like Streetfighter mentioned, the 1977 had a 22mm round bung and 1978 changed to a flange type petcock. Mine is the flange style.
- Kofla
03 Jan 2026 07:18I've a 1978A KZ1000 tank but Where are You located? I'm in Kansas. Like Streetfighter mentioned, the 1977 had a 22mm round bung and 1978 changed to a flange type petcock. Mine is the flange style.
I am in Philadelphia. Will send you my email address on a private message to discuss price and to see pictures. Thanks.
- asphalt900
- Kofla
05 Jan 2026 08:28
No Longer Needed, Found The Fuel Tank I Was Looking For. Thanks.
Maybe a moderator can change the subject title. I am unable to change it.
05 Jan 2026 08:46Your wish is my commandNo Longer Needed, Found The Fuel Tank I Was Looking For. Thanks.
The following user(s) said Thank You: !Seymore, Kofla
- asphalt900
06 Jan 2026 06:59
Kofla got my 1978 tank. Had to knock the dust off it but boxed/labeled due for UPS this morning. We had fun chatting on the "phone", Yes, persons still do that, ha. Kofla is a Cool Cat and best wishes on his project!!
The following user(s) said Thank You: StreetfighterKz
- Kofla
08 Jan 2026 08:55 - 08 Jan 2026 08:56
The fuel tank arrived this morning; it was in excellent shape as you described. It was great talking with you! Thank you so much!
Last edit: 08 Jan 2026 08:56 by Kofla.
