Kawasaki OEM KZ900 Early KZ1000A model shocks
- asphalt900
07 Aug 2025 03:11
Doing a KZ900 Original Restoration and needing a pair of original shocks Please! Requirements are nice lower dampers/preload selectors, straight and NO wear along piston shaft. Also Pit/Corrosion/Dent free upper metal cans. Springs can be rusty a bit, replacing anyway. Also noteworthy but hard to determine, Damping, can't be leakers. I'm not asking for too much am i??
- Mcdroid
- Gone Kwackers
Re: Kawasaki OEM KZ900 Early KZ1000A model shocks
07 Aug 2025 09:19
Greetings mon ami:
I have a set of original rears on my KZ1000A1 BUT the uppers are a bit rusty. When the motorcycle was last ridden, they did not leak...springs are rusty. I already have a set of replacements. I'll sent you a photo.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- asphalt900
07 Aug 2025 10:06
Merci mon ami! Couldn't count how many of those i'd pitched in the weekly trash over the years. Until i started redoing them, little late now, ha. I still have about 3 but the tops are riddled with spotty pits of rust and rechroming never gives the results of the original finish. Wrong kind of shiny if that makes sense. Did You ever source a centerstand?
- Mcdroid
- Gone Kwackers
07 Aug 2025 10:28
Well, I guess this set of rear shocks also goes into the trash
. And I did find a crusty KZ1000A1/2 centerstand...which cleaned up nicely in Evapo-rust.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- asphalt900
07 Aug 2025 10:35
Before you do something with those shocks peek down around the piston rod, where it comes thru the damper, and see if that rod is shiny all around the circumference. Sometimes the bits of these are still good, they come apart in about 10 minutes each.
