Zn1100 tank and side covers
- kawsakiman
03 Aug 2025 17:20
Well, she has been sitting a couple years.
I did drain her first
No help. Pinhole in tank now.
Looking for a set of bodywork. Doesn't even have to be matching, just not all damaged.
Or any ideas how to seal this Damm hole up.
- asphalt900
Re: Zn1100 tank and side covers
04 Aug 2025 00:02
Is it a singular hole or pincushion multiple holes? More often then not a singular hole is just a glimpse of a much bigger problem, rotting out. Unless caused by some sort of wreck/mechanical incident. I've brazed/soldered my share of tanks but you will find you'll have to remove a larger area of paint to access said hole. And often finding more compromised areas. A lot of fellas "coat/line" the tank but really need to fix the source first and not just depend on the jelly to fill imperfections. You'll be sorry if you don't. That new paintjob with bubbles popping up will be disappointing! Don't have any ZN tanks, too new of a machine for me. Maybe find one on ebay?? Have Fun!
