Cam Plugs and valve cover gasket for KZ1100 Spectre
  • KZQ
  • KZQ's Avatar Topic Author
  • Administrator
  • Administrator
10 Jun 2025 08:52
#913576
Hi Folks,
I've been to PartZilla, Revzilla and Z1 Enterprises looking for a valve cover gasket and cam plugs for my 1100 Spectre with no luck.
Does anybody know of a source for these parts?
Is there any quality difference between Vesra and Athena gaskets?
TIA
Bill
www.KZ1300.com
Riders:
Projects:
1985 ZN1300
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Cam Plugs and valve cover gasket for KZ1100 Spectre
10 Jun 2025 10:15
#913580
I looked at CMSNL in the Netherlands.  They show a Kawi cover gasket (PN 11009-1205) for $57.66.  Fitment for all J-model engines up through 1990 P-model.  Cam end plugs (92066-1106) at $20.55/each. Fit above models and up through 2000 P-model.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • TexasKZ
  • TexasKZ's Avatar
10 Jun 2025 12:24
#913588
I recently purchased some aftermarket ones from Webike that are black anodized. Sexy looking, but I cannot yet attest to their sealability. I am pretty sure all the J engines use the same plugs, save for the finish. The polished ones can be made black pretty easily. The only Athena gaskets I have seen complaints about are the green base gaskets.
  • TexasKZ
  • TexasKZ's Avatar
10 Jun 2025 12:45 - 10 Jun 2025 12:46
#913590
Both PMC and M-Tec gaskets at Webike.
japan.webike.net/ps/#!p.m=467&p.c=1316&p.sk=1
Last edit: 10 Jun 2025 12:46 by TexasKZ.
  • Nessism
  • Nessism's Avatar
11 Jun 2025 05:59
#913606
Athena gaskets, even things like for a valve cover, use inferior materials compared to OEM.  The OEM gaskets are higher density, and coated.  Athena are more porous, tear easily.
The following user(s) said Thank You: KZQ, TexasKZ, SWest, kimchella
