81-82 Z1000J Needle Jets
- Glenn_22
27 Feb 2025 15:46
Looks like a previous owner tried to force the Needle Jet back into position using a screwdriver directly onto the small shroud and damaged it, one of the others is also a little beaten about as well.
Does anyone have one or two or a full set they would like to sell me please?
According to the Parts Catalog it is 16017-1085, mine are stamped Y-6
Cheers
Cheers
1981 Kawasaki Z1000J1
1983 Yamaha RZ350
1986 Yamaha TZR2501KT
1995 Yamaha TZR250SPR Sugo
2022 Husqvarna TE250i
1983 Yamaha RZ350
- asphalt900
- Glenn_22
Re: 81-82 Z1000J Needle Jets
28 Feb 2025 14:30This message contains secure information
1983 Yamaha RZ350
1983 Yamaha RZ350
- Glenn_22
03 Mar 2025 18:29
G'Day mate I sent you a PM with my details, let me know how much $ and I can do a bank transfer for you.
Cheers
Glenn
Cheers
Glenn
1983 Yamaha RZ350
1983 Yamaha RZ350
- asphalt900
05 Mar 2025 12:08
What's You're Post code Glenn? Sorting shipping to get to town with, Clay
The following user(s) said Thank You: Glenn_22
- Glenn_22
05 Mar 2025 13:03
Hi Clay
Post code is 4159
Cheers
Glenn
Post code is 4159
Cheers
Glenn
1983 Yamaha RZ350
1983 Yamaha RZ350
- Glenn_22
19 Mar 2025 12:51
Hi Clay Just following up, did you manage to get the jet posted? What do I owe you?
Cheers Glenn
Cheers Glenn
1983 Yamaha RZ350
1983 Yamaha RZ350
- Glenn_22
20 Mar 2025 14:05This message contains secure information
1983 Yamaha RZ350
1983 Yamaha RZ350
- asphalt900
22 Mar 2025 08:57
Cheese and Rice, finally found time to dig them puppies out, 364-Y6. Do You have the corresponding Jet Needles, 5FLZ50 (adjustable 5-position) in decent shape? I have those too if yours are mishandled.
- asphalt900
22 Mar 2025 09:32
I looked it up, jetting, and wildly different in the Sites visited. But i've seen this time and time again. Everything stated Y1, have plenty of those but not what You seek. So i just pulled a couple straight from the source carb, ha.
- Glenn_22
22 Mar 2025 15:07
Hi Clay Yep 364-Y6 are what I need for the Australian model, my 5FLZ50 (5 Groove) needles look ok from a visual inspection but I don't know how to check if they're worn, to be sure I'd be happy to get the jets and needles as a matching set please.
Thank you so much
Thank you so much
1983 Yamaha RZ350
1983 Yamaha RZ350
- Glenn_22
04 Apr 2025 13:46
Hi Clay I'm keen to get the carbs sorted, all my required engine parts are on their way so won't be too long before I'll be ready to refit the carbs and fire it up, do you still have the Y6 Needle jets and 5FLZ50 Needles available?
Cheers
Glenn
Cheers
Glenn
1983 Yamaha RZ350
1983 Yamaha RZ350
