  • Page:
  • 1
KZ900 throttle cable pulley 05 Jun 2023 20:39 #885674
  • LukasLee
  • LukasLee's Avatar Topic Author
  • Thank you received: 2
Does anyone have a throttle cable pulley part #16068-011 that they would be willing to part with ?
1979 KZ1000 LTD
1978 CB750F
2012 FLHTK
KZ900 throttle cable pulley 06 Jun 2023 06:43 #885685
  • Mikaw
  • Mikaw's Avatar
  • Away
  • Thank you received: 1759
I’ll look after work today. About 4:00 eastern time zone
EDIT, there are at least two different cable pulleys I know of. Do you have one to match to?
Last edit: by Mikaw.
KZ900 throttle cable pulley 06 Jun 2023 07:13 #885686
  • Nessism
  • Nessism's Avatar
  • Thank you received: 2527
Matt is correct, there are a few variants of these pulleys.
Found this photo, matched to the PN.  I assume it's correct, but can't guarantee.
KZ900 throttle cable pulley 06 Jun 2023 21:10 #885716
  • LukasLee
It is the same as the one in the pic, I also need the idle adjustment thumb screw. Thanks
1979 KZ1000 LTD
1978 CB750F
2012 FLHTK
Last edit: by LukasLee.
KZ900 throttle cable pulley 07 Jun 2023 09:21 #885737
  • Mikaw
  • Mikaw's Avatar
  • Away
They will look identical but the indexing of the bolt to the shaft is different. I forgot last night, I’ll look today
KZ900 throttle cable pulley 09 Jun 2023 13:20 #885812
  • LukasLee
I looked again, appears to be the same one as in the pic. Wouldn't a different variant have a different part # ?
1979 KZ1000 LTD
1978 CB750F
2012 FLHTK
KZ900 throttle cable pulley 10 Jun 2023 11:20 #885838
  • Mikaw
  • Mikaw's Avatar
  • Away
Apologize for the delay. This is what I found. I’d have to dig more if this is not the correct one.
Bottom one is from a set of 28mm pumpers. Top should be what you need
KZ900 throttle cable pulley 10 Jun 2023 11:26 #885839
  • Mikaw
  • Mikaw's Avatar
  • Away
Hold on!!! Maybe not. I flipped the top one to compare to the photo Nessism posted. Mine is timed differently. Mine the fixing bolt points toward 11:00. Nessism picture it looks more like 1:00
KZ900 throttle cable pulley 10 Jun 2023 11:31 #885840
  • Mikaw
  • Mikaw's Avatar
  • Away
Side by side. I’ll dig more to see if I have what you need
KZ900 throttle cable pulley 12 Jun 2023 15:54 #885914
  • Nessism
  • Nessism's Avatar
I have two of the same type as Matt.  The piece in question is for the early version VM26's, the type with the angled bracket on top.
KZ900 throttle cable pulley 17 Jun 2023 18:12 #886113
  • LukasLee
OK thanks for looking . I found a few more places to check with.
1979 KZ1000 LTD
1978 CB750F
2012 FLHTK
  • Page:
  • 1
