  • Page:
  • 1
Front caliper piston KZ400 B2 04 Oct 2022 00:34 #874986
  • Michel3007
  • Michel3007's Avatar Topic Author
  • Thank you received: 14
Hi,
I am on the hunt for a piston for my KZ400 B2 front caliper. The partzilla reference is 43048-005. I can't find it anywhere (ebay, cmsnl, ...).
If anyone has one, please give me a shout.
Cheers,
KZ 750 H2 LTD 1981
GPZ750R1 1982
Front caliper piston KZ400 B2 06 Oct 2022 12:03 #875180
  • Michel3007
Quick question, I may have found a replacement piston (one for the Discovery 1 Range Rover)
Here are the dimensions:
- Stock piston : 41mm diameter, 31mm height
- Range Rover piston: 41mm diameter, 34mm height
Do you think that these 3 mm longer in height are a big problem ?
I am gonna go ahead and buy one anyways, will report how it fits.
KZ 750 H2 LTD 1981
GPZ750R1 1982
Last edit: by Michel3007.
Front caliper piston KZ400 B2 06 Oct 2022 12:27 #875181
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
  • Thank you received: 309
Have you checked with brakecrafters.com? They have found us hard to find caliper pistons twice.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1981 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
And more
Front caliper piston KZ400 B2 06 Oct 2022 14:19 #875185
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Thank you received: 1821
If you can't source the correct part I would suggest getting the LR part machined down to the correct height (whilst it may physically fit the extra height is likely to cause binding when hot which could ultimately lead to it locking on which would be bad for your health)
Front caliper piston KZ400 B2 07 Oct 2022 11:11 #875220
  • Michel3007
I have sent a message to brakecrafters to see if they may find this elusive piston. Thank you for the advice Kelly.
Wookie, would you think that a shorter piston than stock would be better then ? I recall finding one of 28mm height during my research.
KZ 750 H2 LTD 1981
GPZ750R1 1982
Front caliper piston KZ400 B2 07 Oct 2022 12:03 #875222
  • Wookie58
  • Wookie58's Avatar
  • Moderator
Possibly but as the pads wear it may come out too far and kink over to one side ?
The following user(s) said Thank You: Michel3007
Front caliper piston KZ400 B2 07 Oct 2022 15:33 #875229
  • TexasKZ
  • TexasKZ's Avatar
  • Thank you received: 2076
Seems to me that to kink would necessitate the piston to be clear of the fluid seal. If that happened, I think there would be a much bigger problem as I doubt if the dust seal could withstand the pressure of the fluid.
Seems like a slightly longer one would be ok as long as it did not bottom out on the caliper with new pads, and a slightly shorter one would be ok as long as it did not come past the fluid seal with worn pads. A lot of careful measuring would be in order. Machining a long one to the correct length seems like a workable solution as long as the machinist understands that the outside of the piston is delicate and cannot be damaged.
The following user(s) said Thank You: Michel3007, Wookie58
Front caliper piston KZ400 B2 10 Oct 2022 10:16 #875371
  • Michel3007
Thank you both for your replies. Looks like I have to choose between 3 mm shorter or 3 mm longer...
The longer one is on its way, so I guess the choice is made. I will make sure it does not touch the bottom of the caliper with the pads on. If it does, I will cut the piston shorter.
Brakecrafters answered and they do not have that in store, it has been discontinued.
KZ 750 H2 LTD 1981
GPZ750R1 1982
Front caliper piston KZ400 B2 10 Oct 2022 12:16 #875381
  • Wookie58
  • Wookie58's Avatar
  • Moderator
Makes sense, if it ends up being marginal you could always shave the pads for clearance
  • Page:
  • 1
