- Thank you received: 49
78 kx650 stator cover
- katit
- Thank you received: 2841
- katit
- Thank you received: 1093
- katit
- Thank you received: 2074
- katit
And.. Cost of timesert kit for M5/M4 (not sure which one need to check) will probably be close to another cover.
Use the stator body screw holes as a bore guide to center pilot 6 mm drill bit, easy naa....How? It's not about just inserting it. It's about making it in correct location. Hole drilled off-center. How do I drill it to restore correct position?
- katit
Duh.. Ok. I guess I am trying to overthink stuff.
Anyhow.. M5 (this is what it is) timesert kit is like $80.
I will see maybe use my M6 timesert kit if there is enough meat and then just enlarge hole in stator body a little.. Hope it works.
- Thank you received: 1656
There's one from a 79 model that's $28T but it doesn't have the cross-hatch pattern. None of them looked that great.
search terms I used: KZ650 generator cover. also searched KZ650 with: alternator cover. stator cover. dynamo cover. engine cover.
- katit
It´s a M6 bolt thread you have to repair....
Nope. This is M5 allen bolts ther
BOLT-SOCKET,5X30 (Ref # 28) 120P0530
