78 kx650 stator cover
22 Apr 2021 19:41 - 22 Apr 2021 20:02 #847256 by katit
78 kx650 stator cover was created by katit
Unfortunately I don't think I can have this thread saved. Anybody has spare?
  • Last edit: 22 Apr 2021 20:02 by katit.
    22 Apr 2021 20:12 #847258 by Nessism
    Replied by Nessism on topic 78 kx650 stator cover
    Why not install a helicoil?  Auto parts stores sell kits with the appropriate tap.  Just make sure to use the correct drill bit first.
    22 Apr 2021 20:18 #847260 by katit
    Replied by katit on topic 78 kx650 stator cover
    Its drilled off center, no way I can drill it correctly for helicoil. I believe it’s m5 in there and pretty tight clearance. If inexpensive cover available Id rather replace. I have one from 79 but it looks little different on logo, also a possibility
    • hardrockminer
    23 Apr 2021 04:58 #847267 by hardrockminer
    Replied by hardrockminer on topic 78 kx650 stator cover
    Have you checked ebay?
    23 Apr 2021 09:21 #847294 by katit
    Sure I did, I was checking community first
    • Scirocco
    • Premium Member
    23 Apr 2021 11:44 #847298 by Scirocco
    Replied by Scirocco on topic 78 kx650 stator cover
    There is a lot of Aluminum left to do a Timesert repair!!!
    23 Apr 2021 12:08 - 23 Apr 2021 12:09 #847299 by katit
    How? It's not about just inserting it. It's about making it in correct location. Hole drilled off-center. How do I drill it to restore correct position?
    And.. Cost of timesert kit for M5/M4 (not sure which one need to check) will probably be close to another cover.
    Last edit: 23 Apr 2021 12:09 by katit.
    • Scirocco
    • Premium Member
    23 Apr 2021 12:28 - 23 Apr 2021 12:29 #847302 by Scirocco
    Use the stator body screw holes as a bore guide to center pilot 6 mm drill bit, easy naa....
    Last edit: 23 Apr 2021 12:29 by Scirocco.
    The following user(s) said Thank You: katit
    23 Apr 2021 12:36 #847303 by katit
    Duh.. Ok. I guess I am trying to overthink stuff.
    Anyhow.. M5 (this is what it is) timesert kit is like $80.
    I will see maybe use my M6 timesert kit if there is enough meat and then just enlarge hole in stator body a little.. Hope it works.
    • Scirocco
    • Premium Member
    23 Apr 2021 12:45 #847304 by Scirocco
    It´s a M6 bolt thread you have to repair....
    23 Apr 2021 12:51 #847306 by martin_csr
    Replied by martin_csr on topic 78 kx650 stator cover
    I only found 5 or 6 like yours with the cross-hatch pattern on EB. one of them is nos & over-priced.  3 or 4 are in the $55T range.
    There's one from a 79 model that's $28T but it doesn't have the cross-hatch pattern.  None of them looked that great.
    search terms I used:  KZ650 generator cover. also searched KZ650 with: alternator cover. stator cover. dynamo cover. engine cover.
    23 Apr 2021 12:57 #847307 by katit
    Nope. This is M5 allen bolts ther
    BOLT-SOCKET,5X30 (Ref # 28) 120P0530
