wantd: Kawasaki tank badges ....KZ650/900/1000
  • MotorCityMN
  • MotorCityMN's Avatar Topic Author
24 Mar 2021 07:54
#845434
Hello all,
Looking for a set of Kawasaki fuel tank badges.   Can either be from KZ650,  900 or 1000.
Thanks in advance.
  • H1Vindicator
  • H1Vindicator's Avatar
Re: wantd: Kawasaki tank badges ....KZ650/900/1000
24 Mar 2021 08:24 - 24 Mar 2021 08:24
#845436
Just an FYI.  I'm not certain, but any old tank emblem may not work.  The tank emblems vary in style & possibly the spacing between the mounting holes may vary.  So you might want to verify the spacing before buying.  Good luck.
Last edit: 24 Mar 2021 08:24 by H1Vindicator.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Away
  • Moderator
  • Moderator
24 Mar 2021 08:27
#845438
Hello all,
Thanks in advance.
Do you plan on installing them on a tank , or are they for another purpose ?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
24 Mar 2021 11:05
#845448
I had used the PMC self adhesive enblems, best quality you can get for your money.
Two different sizes 122 mm screw pattern and 168 mm length and 140 mm screw pattern and 190 mm length
Search on www.japan.webike.net or www.win-pmc.com
