Transmission cover, #14024-011
- kzrider
- Administrator
05 Oct 2015 08:20
Need a transmission cover for the Z750 B1, part# 14024-011. I believe this part number was shared between quite a few KZs, but since Kawasaki.com no longer lets you search for part numbers, I didn't find an easy way to pull up a list.
1976 Z750 B1
1980 Z1000 MkII A4
1980 Z1000 MkII A4
- Kidkawie
- I bleed premix
Re: Transmission cover, #14024-011
05 Oct 2015 08:42 - 05 Oct 2015 08:42
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
Last edit: 05 Oct 2015 08:42 by Kidkawie.
- kzrider
- Administrator
06 Oct 2015 09:15
Thanks kidkawie! So, does anyone have a transmission cover from one of the bikes below they would be willing to part with? Found a new one in Germany, but at €70 plus shipping I'm holding out for a good used one
1976 KZ750-B1 ENGINE COVERS
1977 KZ650-B1 ENGINE COVERS
1977 KZ650-C1 Custom ENGINE COVERS
1977 KZ750-B2 ENGINE COVERS
1978 KZ650-B2 ENGINE COVERS
1978 KZ650-B2A ENGINE COVERS
1978 KZ650-C2 Custom ENGINE COVERS
1978 KZ650-D1 SR ENGINE COVERS
1978 KZ650-D1A SR ENGINE COVERS
1978 KZ750-B3 ENGINE COVERS
1979 KZ650-B3 ENGINE COVERS
1979 KZ650-C3 Custom ENGINE COVERS
1979 KZ650-D2 SR ENGINE COVERS
1979 KZ750-B4 ENGINE COVERS
1980 KZ550-A1 BREATHER COVER-OIL PAN ('80-'81 A1-A2)
1980 KZ550-C1 LTD BREATHER COVER-OIL PAN ('80-'81 C1-C2)
1980 KZ650-E1 LTD ENGINE COVERS
1980 KZ650-F1 ENGINE COVERS
1980 KZ750-E1 ENGINE COVERS ('80 KZY 50-E1)
1980 KZ750-E1 ENGINE COVERS ('81 -'82 KZ750-E2-E3)
1980 KZ750-G1 LTD II BREATHER COVER-OIL PAN
1980 KZ750-H1 LTD ENGINE COVERS ('80 H1)
1980 KZ750-H1 LTD ENGINE COVERS (KZ750-H2-H3)
1981 KZ550-A2 BREATHER COVER-OIL PAN ('80-'81 A1-A2)
1981 KZ550-C2 LTD BREATHER COVER-OIL PAN ('80-'81 C1-C2)
1981 KZ550-D1 GPz BREATHER COVER-OIL PAN
1981 KZ650-H1 CSR ENGINE COVERS ('81-'82 H1-H2)
1981 KZ750-E2 ENGINE COVERS ('80 KZY 50-E1)
1981 KZ750-E2 ENGINE COVERS ('81 -'82 KZ750-E2-E3)
1981 KZ750-H2 LTD ENGINE COVERS ('80 H1)
1981 KZ750-H2 LTD ENGINE COVERS (KZ750-H2-H3)
1982 KZ550-A3 BREATHER COVER-OIL PAN ('80-'81 A1-A2)
1982 KZ550-C3 LTD BREATHER COVER-OIL PAN ('80-'81 C1-C2)
1982 KZ650-H2 CSR ENGINE COVERS ('81-'82 H1-H2)
1976 Z750 B1
1980 Z1000 MkII A4
1980 Z1000 MkII A4
- mariozappa
06 Oct 2015 09:36
I should have one in good condition from one of my 650 engines.
I will check tonight and get a picture.
1977 KZ650C1
and the KZ650/KZ750 Conversion
06 Oct 2015 10:35
I've got one you can have for free, but think the little extension piece on top is broke off.
- kzrider
- Administrator
07 Oct 2015 03:20
mariozappa: Excellent!
Nessism:
The one in the ebay link is for an '82 GPZ 550 (H2) and is a tiny bit different than the one I need. It has a hole for a dowel pin or something in the top left corner, while mine doesn't.
Nessism:
1976 Z750 B1
1980 Z1000 MkII A4
1980 Z1000 MkII A4
07 Oct 2015 03:44 - 07 Oct 2015 05:14
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationHere's one from a 1980 KZ750, but the exact model isn't specified. maybe a 750E? I guess they were in a hurry to remove it. It might be a pain in the you-know-what extracting all of the broken bolts.
1980 KAWASAKI KZ750 KZ 750 KM144B ENGINE CRANKCASE SIDE SPROCKET GUARD COVER
Edit: several more from the same seller: search = KZ650 engine cover
Last edit: 07 Oct 2015 05:14 by martin_csr.
- Kidkawie
- I bleed premix
07 Oct 2015 04:44kzrider wrote: Thanks kidkawie! So, does anyone have a transmission cover from one of the bikes below they would be willing to part with? Found a new one in Germany, but at €70 plus shipping I'm holding out for a good used one
I found the Partzilla diagrams the next best thing to the old Kawasaki diagrams. They recently changed their site so you have to log in to get access to the full diagram info, but if you search Google using the part number you kind of get a "back door" to the diagrams.
1975 Z1 900
2004 KX125
2004 KX125
- mariozappa
07 Oct 2015 11:09
I didnt have time to find last night, I will get it tonight.
1977 KZ650C1
- mariozappa
07 Oct 2015 14:40 - 07 Oct 2015 14:45
ok, here ya go.
i.imgur.com/t29YgbW.jpg
i.imgur.com/H5LGyK8.jpg
Upon further inspection the bottom bolt that holds the guard on the mission cover is broken off.
1977 KZ650C1
Last edit: 07 Oct 2015 14:45 by mariozappa.
07 Oct 2015 16:39
That's easy to fix.
- kzrider
- Administrator
08 Oct 2015 04:25mariozappa wrote: ok, here ya go.
I should be able to drill that bolt out.
How much do you want for it?
1976 Z750 B1
1980 Z1000 MkII A4
1980 Z1000 MkII A4
