Drag frame and basket case motor
- udder
09 May 2026 12:25 - 09 May 2026 17:36
Selling a late 70s kawasaki kz1000 modified frame. Frame has welded swing arm. Maybe stretched. It ran on the track for many years. I can get more info from the previous owner/builder as needed. Selling frame as a roller with the air shifter and shift programmer. Does not come with track motor. I am taking the track motor for my personal rider. What o have to go with it is a 78 kz1000 motor completely disassembled. Comes with an oversized jug and piston set. Everything ran with the motor before disassembly. Reason for teardown was due to broken carb boot lug on the jug. Has been welded back in place. Will not come with charging system. . Will take better photos of whatever you need to see. No title.Taking offers
Last edit: 09 May 2026 17:36 by udder. Reason: Mis print
- udder
- udder
Re: Drag frame and basket case motor
09 May 2026 13:04
Swingarm 6 inch over....raked front end....chasis has seen sub 10 second runs. Good bracket racer setup
- udder
13 May 2026 07:35 - 13 May 2026 07:36
See my other post for photos and info.
www.kzrider.com/forum/25-racing/622752-d...nd-basket-case-motor
Last edit: 13 May 2026 07:36 by udder.
13 May 2026 07:46
Udder please keep to one thread per topic (you already had responses on the other thread) I have merged the two threads and moved to the "for sale" section
- udder
