Wiseco K1075 72mm 4052M07200 10.25cr
  • asphalt900
  • asphalt900's Avatar Topic Author
11 Nov 2025 05:30
#918957
Since Daveo brought up piston woes and I'm in that mindset, i'll peddle these "almost" new 72mm Wiseco K1075 piston assemblies, again. No gaskets, just the pistons/rings/pins and circlips. Good stuff barely used in misapplication from a "shop" that tried to use them in a 1982 J engine..go figure how that wouldn't be immediately relevant because of the lower "obvious"        piston top to deck height, ha. Anyway..they tried to get it to running and failed. So i acquired the engine and put the correct "J" pistons in it, these are the pull-outs. All just fine, just take your 1977-1980 cylinder/liners to a proficient machine shop to turn your 70mm stock bore to 72mm with a bump in compression vs stock. By far the most popular upgrade piston set used while still maintaining reliability. 450.00USD shipped to the 48. Questions/concerns PM or call 816-365-8687 Clay
The following user(s) said Thank You: daveo, Dragbike_Mike, Gdizard
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: Wiseco K1075 72mm 4052M07200 10.25cr
12 Nov 2025 17:29
#919022
Nice looking pistons, and thanks for responding to my engine post with thoughtful comment!
Where is everybody anyway?
1982 KZ1100-A2 bike powered by a 1984 ZN/ZX1100 motor since late 2024
  • asphalt900
13 Nov 2025 02:42
#919031
It's almost winter, everyone is in a flurry to "batten down the hatches", ha.
  • sf4t7
  • sf4t7's Avatar
13 Nov 2025 15:29
#919056
Or staring out the window at the thermometer hoping for just one more ride this season !
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
  • TexasKZ
  • TexasKZ's Avatar
13 Nov 2025 18:00
#919059
Or enjoying a sunny, 80F day.
The following user(s) said Thank You: Mcdroid, sf4t7
  • asphalt900
14 Nov 2025 02:29
#919066
Speaking of "winterizing". We have 3 separate forced air heaters to keep this castle warm. Went to start one up and no-go. Furnace Control Board received a surge when we had a bolt of lightening strike a couple months ago hit a tree 100 foot away from the house but right on top of the power line. A new White-Rodgers (Emerson) board and i too can stare out the window sf4t7, in comfort though ha.
  • Powerstroke_fan
  • Powerstroke_fan's Avatar
Today 17:56
#920064
Ill send you a pm.
1977 KZ 1000 work in progress
  • asphalt900
Today 01:53
#920067
PM back at You Powerstroke.
  • Dragbike_Mike
  • Dragbike_Mike's Avatar
Today 04:52
#920069
These pistons, combined with a mildly ported head, mild cams and small(ish) carbs, would make for a sweet running street motor - or race motor, for that matter.  More than enough reliable power for 99.9% of the time, IMHO.
And, for the lucky buyer of these pistons, I'd go the additional mile and gently radius the valve pockets and polish the domes.  Doesn't cost you anything and your motor will thank you.
Mike
