- Thank you received: 274
KZ1000 1979-1980 Cylinder Head
- asphalt900
27 May 2024 05:46 #899801
by asphalt900
KZ1000 1979-1980 Cylinder Head was created by asphalt900
Anyone needing a 79-80 KZ1000 head? Needs a valve seat job. It's already been surfaced. Has the cam-caps original to it. I pulled it off a drag turbo bike years ago. Someone fudged-up the tach drive opening with a pipe tapered plug. So running a tach you might have to go electronic or the seat of your pants and feel the revs. I'll get some decent pics if any interest.
- asphalt900
27 May 2024 05:48 #899802
by asphalt900
Replied by asphalt900 on topic KZ1000 1979-1980 Cylinder Head
Forgot to mention, stock size valves and a cam cover to suit.
- asphalt900
27 May 2024 06:07 #899804
by asphalt900
- asphalt900
27 May 2024 06:41 #899805
by asphalt900
More stuff. Tired of moving it from top of box to top of another box. Comes with decent shim buckets and spring seats. NO Valves
- asphalt900
27 May 2024 10:07 #899812
by asphalt900
- asphalt900
27 May 2024 10:10 #899813
by asphalt900
Thanks for the Kudos Steve!! Think of all the work You'd of saved Yourself in the past if you lived down the street. I have a gaggle of these, he.
- Vinsky
- Thank you received: 83
27 May 2024 15:30 #899827
by Vinsky
Vinsky
Replied by Vinsky on topic KZ1000 1979-1980 Cylinder Head
Where are you located? Don't see it in your profile.
Vinsky
- asphalt900
28 May 2024 01:55 #899837
by asphalt900
In the middle of nowhere, Paola Kansas. Aren't You a British bike enthusiast too? Might like the looks of one of these, 1973 Commando, gotta be versatile around here. Restoring for a friend. Noticed on Jims post You'd inquired about how i get that o-ring bowl thingy to function. Did you get the 28's done for your friends Z1R?
The following user(s) said Thank You: Vinsky
- asphalt900
28 May 2024 04:55 #899844
by asphalt900
Another unorthodox application of possibilities. I do my fair share of the GT750 carbs, early slide, later CV. Works on all, and for a reason. Not shown but a similar "thinking" GS400 Mikuni float bowl. Note these have all air correction connections centralized in the middle of bowl and casting. Over time the casting bows at the corners leaving the center to just suck sloshing petrol from the bowl. I create a labyrinth of correcting rubber to compensate. Just sent a set of the later CV GT750's off to a friend in Virginia that implemented this wacky procedure. Ran great. Ya won't find this mindset in any FSM.
- Vinsky
28 May 2024 06:55 - 28 May 2024 07:07 #899858
by Vinsky
Vinsky
Yeh, Brit bikes all over the shop. Grew up not far from you, Fort Scott, Ks. Small world ain't it. The Z1R is mine and getting rebuilt after 30 years of neglect.
Vinsky
Last edit: 28 May 2024 07:07 by Vinsky.
- asphalt900
28 May 2024 09:20 #899863
by asphalt900
It is a small globe for sure! Haven't been to Ft Scott for a while and You know why, nothing there to see, ha. Used to have a couple lots out at Sugar Valley in Mound City, basically a mowing job for the weekends.
- Dragbike_Mike
- Thank you received: 106
29 May 2024 05:17 #899932
by Dragbike_Mike
Mike
Presently - 1980 KZ1000B4 LTD w/mild ported head, Megacycle cams, 1015cc Wiseco, Falicon Supercrank, R&D undercut trans
Replied by Dragbike_Mike on topic KZ1000 1979-1980 Cylinder Head
I'm thinking that those retainers are anodized aluminum. Still good stuff, just not as "trick" as titanium would be...Some RC SOB spring retainers. A complete set of 8. Maybe TI retainers, would assume??
Mike
