suggestions for uncommon tools
  • psiongrain
  • psiongrain's Avatar Topic Author
09 Sep 2026 11:47
#927391
i'm finally in a place where i can start grabbing tools that i will need to repair my 1982 kz 750 ltd. i've seen videos about the motorcycle mechanics tool box so i have a decent idea of most tools i will need but i was wondering if anyone had any suggestions for more unique tools or maybe costly but worth it tools that have helped them with working on older bikes? really any advice is useful advice here. thanks
  • Warren3200gt
  • Warren3200gt's Avatar
Re: suggestions for uncommon tools
09 Sep 2026 11:54
#927392
JIS Screwdriver set.
The following user(s) said Thank You: StreetfighterKz, Mcdroid, asphalt900, Dragbike_Mike, Kelly E
  • Nerdy
  • Nerdy's Avatar
09 Sep 2026 13:34
#927393
Fiberglass pens for cleaning electrical contacts
Headlamp
Good quality wire strippers and a selection of bullet connectors
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
The following user(s) said Thank You: Mcdroid, slmjim+Z1BEBE
  • Nessism
  • Nessism's Avatar
The following user(s) said Thank You: asphalt900, Kelly E
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
09 Sep 2026 14:12
#927395
I would advise you buy as and when you find things you need. It’s easy to get “ the fever” and spend a small fortune on things you will never use
The following user(s) said Thank You: asphalt900, Kofla
  • moizeau
  • moizeau's Avatar
09 Sep 2026 14:28
#927396
Very true, but JIS screwdivers are a must.
The following user(s) said Thank You: Mcdroid, Wookie58
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
09 Sep 2026 18:03
#927398
Here's a basic list with a few bigger tools that really make life easier.
Two good sets of metric combination wrenches
1/4 "- 3/8"- 1/2" sockets in 6 and 12 point, standard and deep with plenty of various extensions
inch pounds torque wrench
a selection of hammers including deadblow and soft
a selection of pliers and vise grips
steel punch set
brass punch set
multi meter
electrical connectors/soldering gun with electronic solder and heat shrink
cordless impact gun with a selection of bits and drivers
compressor and air tools
motorcycle lift table
solvent wash tank, preferably petroleum base solvent
a couple of scissors jacks
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
The following user(s) said Thank You: Kofla, Wookie58
  • asphalt900
  • asphalt900's Avatar
10 Sep 2026 00:37
#927401
Define "uncommon". Or more so, define the tasks You're looking forward to completing? I'm with Wookie on this, don't just willy-nilly empty your wallet. Which category or system of machine needs attention? Some things are better left to professionals, like a valve job. Why would you spend 4-700USD on seat cutters when you can have the whole job done for maybe 250USD.
  • hardrockminer
  • hardrockminer's Avatar
10 Sep 2026 04:43
#927405
My JIS screwdrivers are a great investment but when I think about the tool I should have had in the beginning....I think it's my torque wrench.  Would have saved me a lot of grief when putting engines back together.  I don't use it very often but it has been absolutely necessary when I did.  Guessing at proper bolt torque is a mugs game.
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
10 Sep 2026 06:35 - 11 Sep 2026 02:52
#927411
Tool junkie here.  Must resist writing an epic tome...
Metric thread chaser set and / or thread file.
A ft. - lb. torque wrench and a in. - lb. torque wrench.
If building spoke wheels, a spoke torque wrench.
When working with points, we've come to prefer an analog dwell meter.  Conversion charts are available to convert for wasted-spark ignition systems.
A known-good 12v battery to power a timing light alone.  Ripple from crude DC rectifiers can falsely trigger some timing lights.
If working with 5mm (aka 4.9mm) barrel connectors, a good plier-type (not ratcheting) crimper that makes the conductor crimp and insulator crimp individually.
An analog VOM.  DMM's are convenient but, being able to observe instantaneous needle deflections that can't be resolved by a DMM display can ease electrical troubleshooting.
A DMM that has a sounder to indicate change of state audibly.  A sounder can often substitute for seeing needle deflection of an analog meter.
If you have access to sufficient air volume and the patience to deal with the hose, a 3/8" air ratchet.  Careful of the torque one can produce.
NO-OX-ID "A-SPECIAL" Electrical Grade contact grease to keep those pin & barrel connectors um..., connecting.
EDIT: to add an impact screwdriver.  We have a decades-old Lisle that came with JIS bits before JIS was a well-known thing.  They're still available.  Vessel makes a good one too, with JIS bits.
Those hit the high spots.  Gotta quit while your wallet is still healthy.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
Last edit: 11 Sep 2026 02:52 by slmjim+Z1BEBE. Reason: Added tool.
The following user(s) said Thank You: Nerdy
  • H1Vindicator
  • H1Vindicator's Avatar
10 Sep 2026 07:26 - 11 Sep 2026 07:42
#927415
fork tool for disassembling the fork innards in case the bottom allen bolt is stuck >> LH-threaded 1/2" bolt & nut w 3/4" head. use w ratchet wrench and socket w long extension to hold the inner cylinder while unscrewing the bottom allen bolt. note: bolt-head should accept a 3/4" or 19mm socket. 19mm is the size of the inner cylinder head. some guys just weld a nut to the end of a bolt.
ps: from the diagrams the 750Ltd should use the same tool as the 650csr.   ....  ...... image posted previously on kzr a while ago.
not sure how a spark plug socket would be any better. see following comment. a bolt & nut was cheap and I don't have a spark plug socket to try. ha ha.
Last edit: 11 Sep 2026 07:42 by H1Vindicator.
  • Nessism
  • Nessism's Avatar
10 Sep 2026 09:09
#927419
A spark plug socket, the type with a hex on the bottom, fits the damper rod.  Use a long extension and install it backwards, so the hex is down.
