Engine stand
- davido
Engine stand
04 Sep 2026 08:04
The time has finally come to have a go at painting my engine.I'm going to need and engine stand for cleaning it and painting and I'll need to pop it in the oven to cure,so a metal stand will be best.Has anybody got plans/drawings/dimensions for a stand. Its for a 1981 CSR1000. I think the J model engine.Thanks.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- StreetfighterKz
Re: Engine stand
04 Sep 2026 08:47
Are planning on putting the entire engine in the oven?
I have a K&L engine stand. Only used it a few times in the last 20+ yrs. It is expensive though! I think Wookie may have made an adapter for an automotive engine stand….?
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
- Nerdy
Re: Engine stand
04 Sep 2026 09:00
I'm cutting down a spare frame to make a 400/440 engine stand
It will be really simple, with two horizontal pieces of (probably) 1.5" square mild steel tubing under the engine for lateral stability
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
- davido
Re: Engine stand
04 Sep 2026 11:40
Yes the whole thing will go in the oven,so I need something small and basic. Don't need a rotisserie type, just bolt on the engine mounts front and back. I'm sure I saw plans somewhere a few years ago. When the front mount is loosened the whole engine flips over on the back mounts and vice versa to access the underneath. Maybe I dreamt it.
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
- StreetfighterKz
Re: Engine stand
04 Sep 2026 12:24What temp are you planning on baking the engine? I’d be very wary of going higher than 250-300°F. Most rubber parts aren’t really made for sustained high temps ie Nitrile is good up to 250°F working temp. Just my 2¢.Yes the whole thing will go in the oven
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
1979 z650 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: MFP-Joe, Wookie58
- davido
Re: Engine stand
04 Sep 2026 13:17 - 04 Sep 2026 13:17What I understand from the VHT website is 90 degrees Centigrade (194 Farenheit) for 20 minutes. What's your opinion on that?What temp are you planning on baking the engine? I’d be very wary of going higher than 250-300°F. Most rubber parts aren’t really made for sustained high temps ie Nitrile is good up to 250°F working temp. Just my 2¢.Yes the whole thing will go in the oven
Later, Doug
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
Last edit: 04 Sep 2026 13:17 by davido.
- Kofla
Re: Engine stand
04 Sep 2026 21:42
I wish I had purchased the stand the first time I saw it advertised years ago. It is quite pricey now.
1978 Kawasaki KZ1000 LTD
2010 Kawasaki Ninja ZX-14
Re: Engine stand
05 Sep 2026 00:49
You must have a big oven ? what paint are you planning to use ? I used "air dry" cerekote so no baking required
- slmjim+Z1BEBE
Re: Engine stand
05 Sep 2026 05:52A member here was fabricating & selling a bench stand very similar to that one ~15 yrs. ago. Completely adjustable for a wide variety of motors. Rotates. Breaks down easily for comapct storage. We bought one & have been satisfied with it for Z1 motors. Don't remember price or user name. A cursory KZR search doesn't find it, but we'll keep looking.
This is the stand the KZR member fabricated w / Z1 bottom end mounted. We see The Lovely Z1BEBE, a.k.a. the shop's resident Torque Monster while in one of her preferred habitats, gently fondling case bolts to their proper torque.
Just for tool junkie giggles, here we see stand kits offered by Mama Kaw in the day. The PN's don't come up in any retail documentation we've ever read, only distributor news docs not generally available to the public. We've never seen any in the flesh.
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Re: Engine stand
05 Sep 2026 07:06
Wow! What an ingenious set of stands.
- Nerdy
Re: Engine stand
05 Sep 2026 09:38Just for tool junkie giggles, here we see stand kits offered by Mama Kaw in the day. The PN's don't come up in any retail documentation we've ever read, only distributor news docs not generally available to the public. We've never seen any in the flesh.
Okay, this is odd: for giggles I googled 'kawasaki' and '56019-103', the part number for the engine stand base.
It came up as a factory piston pin puller: www.speedsupplies.com/parts/kawasaki-56019-103.htm
Further googling for 56019-111 (the engine adapter kit to go with the base) seems to indicate it's a "boot remover" for a 400: www.cmsnl.com/kawasaki-kz400s3-special-1...over-boots_56019111/ In the CMSNL diagram it looks like a simple rod with a small hook on the end.
1980 KZ440B
1981 Yamaha XT250H
1981 GPz550
2013 Yamaha FZ6R
- slmjim+Z1BEBE
Re: Engine stand
06 Sep 2026 04:37North American distributor news was published outside of and separate from Mama Kaw's Japanese-sourced corporate retail documentation. Other discrepancies have been documented and have been subjects of arcane discussions for a long time.Just for tool junkie giggles, here we see stand kits offered by Mama Kaw in the day. The PN's don't come up in any retail documentation we've ever read, only distributor news docs not generally available to the public. We've never seen any in the flesh.
None of the PN#'s referenced in those two pages from the NA distributor news publication appear in our Parts Retail Price Guide.
If anyone has hard copy docs published by Mama Kaw corporate Japan that shows those PN#'s & prices, it would be a valuable addition to documented Z1 / Z2 history.
There's a guy in Germany (Achim, for those familiar) who has shelves full of an encyclopedic collection many decades in the making of Mama Kaw's corporate documentation covering all things Z1 / Z2, in English as well as other languages. He's shared a few examples from that library that dive deep into mind numbing, cross referencing rabbit holes of part number conflicts.
Good Ridin'
slmjim & Z1BEBE
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
The following user(s) said Thank You: Nerdy
