Marketing A Tool
- daveo
Marketing A Tool
30 May 2026 11:36
Any folks here actively involved in such a pursuit?
1982 KZ1100-A2/1170 sleeper 😀
Re: Marketing A Tool
30 May 2026 11:56
What tool did you have in mind ? I think the main issue will be convincing a manufacturer there is a market in sufficient volume for it to be cost effectiveÂ
- daveo
30 May 2026 12:14 - 30 May 2026 13:14
Agreed, but the usefulness and market interest should be well evaluated before approaching a manufacturer, correct?
Would also need to determine what material is suitable for the tool to be made from...
At this point the functional prototype material is primarily aluminum, but that part of the tool could possibly be 3-D printed...
Might be getting ahead of myself, but this is exactly where I am with the tool that permitted me to find the valve guide issue in the video below:
photos.app.goo.gl/sQsvTUhpmbzRVYVh8
Last edit: 30 May 2026 13:14 by daveo.
- asphalt900
31 May 2026 02:02
I don't have any collegiate higher learning paperwork to plagiarize from Daveo so nothing fancy in Marketing Terminology. Really just common sense things you've surely already considered. I've only had one "Job", having to file a W-2/W-9, in my entire life. Restaurant job when i was maybe 15/16yrs old. So i've been marketing my whole life under no supervision, scary at times for sure. So just consider what influence your "tool" will have with the end user. It's comparative perhaps already produced similiar "tool" or technique that may not require it. It's Mass Appeal of potential buyers that will justify all the incurred set-up and production costs per unit. Most production shops require a minimum run cost, that cost can be substantial! You might consider, if a totally unique/beneficial twist on whatever application, a Patent Pending application. While just a provisional piece of paper filed thru the USPTO it does carry some weight or dates your original concept. I had one for a polymer based replacement of asphalt/concrete 20 some years ago. Not too hard to do considering i'm not that intelligent and did it ha. Selling to end-user. That is the tricky one! Who would be using your tool? If too specific to one particular dated model/machine you won't have much of a market..period. But overall, keep R&Ding and having fun. More "professional" help can be sought at a minimal cost thru seminars offered thru a program called SCORE. Service Core of Retired Executives.      Â
- daveo
23 Jun 2026 10:21
This tool facilitates valve spring and seal access while the engine remains assembled in the frame with the camshafts removed.
Designed for a KZ1100 J-motor, it should likewise work on others with a similar valve train configuration.
- asphalt900
24 Jun 2026 02:12
Build it and they will come a knocking Daveo! I'm sure you've considered the advantages/disadvantages of this compared to just removing the head since valvetrain has already been dropped out. As you're aware a simple valve guide seal renew is often just the tip of the iceberg of other needed valve guides and valve seating issues. From my experiences "just" having to replace seal(s) wouldn't of fixed anything on these 4cyls. But keep experimenting, i know i do all the time. Not all things are covered in a FSM. My distain for paper gaskets used on the VM Mikuni carbs has lead me to this resolve. Not anything to really Patent but more of a modification of existing bits to fend off those weeping original gaskets that leave brown stains down your float bowls. Have Fun Daveo!!Â
Â
Â
 Â
The following user(s) said Thank You: daveo, sf4t7
- daveo
24 Jun 2026 12:35 - 24 Jun 2026 13:38
Nice solution for the gasket problem.
O-rings may be ideally suited for my tool as well, but that would require having grooves machined...which probably is not a big deal.
I would seriously consider replacing old valve springs and seals if a feasy method (short of head removal) was available...
Cylinder 3 exhaust
...Come to think of it, might swap these in the next time I'm under cover...
Cylinder 3 exhaust
Last edit: 24 Jun 2026 13:38 by daveo.
The following user(s) said Thank You: slmjim+Z1BEBE, asphalt900
24 Jun 2026 14:50
I like the simple but effective nature of it
The following user(s) said Thank You: asphalt900, daveo
- asphalt900
25 Jun 2026 00:38
Nice and tidy Daveo! Thought it was going to be more elaborate?Â
Want some of those keeper retainers in Blue hehe.
- daveo
25 Jun 2026 02:42
Can't seem to shake the good feelings I have about this tool...
- slmjim+Z1BEBE
01 Jul 2026 05:12
  Excellent in its simplicity!
  Have you considered thread durability re: aluminum as material? We can see a shop using that tool to expedite seal replacement. Many, many repetitions of use in a commercial shop environment may tax the wear strength of threads in aluminum past their expected lifespan.
  A hobbyist / restoration enthusiast working in their home shop may never have delved that deep into a head. That person may be attempting a one-off project on the head. What method / advice would you include with the tool to keep a valve from dropping into the cylinder when the keepers are removed?
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- asphalt900
01 Jul 2026 08:03
Here's a unique take on a lapping tool Dave. Made this probably 20yrs years ago when doing those Honda 1979 and later 4 valve heads. The lapper kept sliding off those tiny valve heads/tulips. This way i could vacuum them in place and with flexible tubing to connect to a vacuum source still swivel and finish my task. Actually thought of refining it and shuffling the concept to prosperity but was waay too busy at the time raising children/construction which took all my time to complete. A multi-use tool though, not constrained to a particular Make/Model. That makes All The Difference for production and acceptance. Â
Still use it occasionally, just another tool in the box. The Only flaw i can see in your concept is the Often initial "smack" required to set loose the half keepers from the keeper. They are often bound but i suppose the way you designed your tool you could just put pressure on one side to break that "memory". I truly wish You success!!Â
Â
  Â
The following user(s) said Thank You: slmjim+Z1BEBE, daveo, MFP-Joe
