Pilot needed for my new Neway seat cutters, what size?
  • Gdailey2112
  • Gdailey2112's Avatar Topic Author
  • 82 KZ1100D1
07 Jun 2025 12:58
#913469
I'd purchased new Neway seat cutters, but looking for some information as to which one is most common used, I'm thinking solid tapered covering 7.00mm to 7.03mm
Does that sound about right? Much thanks!!
1982 KZ1100D1
  • Gdailey2112
  • 82 KZ1100D1
Re: Pilot needed for my new Neway seat cutters, what size?
08 Jun 2025 17:44
#913510
Everyone must be out riding LOL BUMP
1982 KZ1100D1
  • Nessism
  • Nessism's Avatar
08 Jun 2025 18:18
#913512
I used a 7.00 solid pilot and it worked perfectly for both my KZ750E and a Suzuki GS1000.
The following user(s) said Thank You: Gdailey2112
  • Rolf1976_KZ900
  • Rolf1976_KZ900's Avatar
10 Jun 2025 00:45 - 10 Jun 2025 00:46
#913566
You measure the valveguide or the valve stem then find a pilot that fits snug .I have used aluminium tape on a pilot once to increase the diameter and it worked fine .
Last edit: 10 Jun 2025 00:46 by Rolf1976_KZ900.
  • Gdailey2112
  • 82 KZ1100D1
14 Jun 2025 04:13
#913717
I bought the CU230 from neway, and a 7.00 to 7.04mm solid pilot from Woodward. I'm gonna put all new guides in whenever I can find the time. Yeah Nessium, I'd read one of your post, said something about the VW world. Man, I had recently inherited my mothers 2006 VW Beetle 1.9 TDI,  ...talk about an expensive learning curve. Always old lady driven, then I got it with 63K on it. Never had timing belt replaced, so I did that right away. Then I'd got me a Ross Tech VAG COM which is frickin awesome. Was merging onto the interstate, gave it a little foot feed when it suddenly ran away. Turns out, when the turbo kicked up, it gulped oil that had collected in the intercooler pipe. Bent 3 connecting rods, YIKES! If it didn't have such low milage, it likely would of been to the bone pile. I just got 'er all buttoned up with new bearings and OEM rods, runs like a top. Also, I tapped the lowest point on the intercooler, installed a sheet metal screw with neoprene o ring. I'll drain it at every oil change. It gets 49 mpg!!! If it didn't have such low milage, it likely would of been to the bone pile.
1982 KZ1100D1
  • Gdailey2112
  • 82 KZ1100D1
14 Jun 2025 06:36
#913722
Maybe it was Sciroco that was talking about Sciroco VW's.
1982 KZ1100D1
  • Nessism
  • Nessism's Avatar
14 Jun 2025 06:55
#913724
I'm no VW guy, sorry.  Didn't Wookie spin wrenches on them?
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
26 Jun 2025 23:51
#914125
I did indeed, this is normally the result of engine oil being overfilled or excessive crankcase pressure. The oil gets drawn up the breather into the airbox at which point the motor will rev to oblivion running on engine oil unless stalled out (E brake on, 5th gear and dump the clutch) Used to be common on the "much" older diesels (VAG made a modified breather take off for the block)
PS: oil residue in the intercooler and intake pipes is normal on all turbo diesels
