Cam installation C Clamp
- Kaw-boy 900
- Let the Good ''Old'' Time Roll !
31 May 2025 06:59 - 31 May 2025 07:11
Work smarter not harder !
I tried to instal cam caps by bolting it down and end up with stripped tread and had to start all over again !
Using C clamps at $10 each was a very good deal that could save me $$$ in helicoils installation.
It work perfectly and easy to use !
Kawasaki and other bike ownend.
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
Harley Softail 2009 For sale !
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
Last edit: 31 May 2025 07:11 by Kaw-boy 900.
The following user(s) said Thank You: MFP-Joe, Dragbike_Mike
Re: Cam installation C Clamp
31 May 2025 09:14
The following user(s) said Thank You: Kaw-boy 900
31 May 2025 12:34
Got to be honest I prefer my "stud and nut" method (it takes longer but not as long as a thread repair), both the clamp methods will work fine but I would worry (particularly with vice grips) that the clamps would mark the head (just my opinion
- Dr. Gamma
06 Jun 2025 16:28 - 06 Jun 2025 16:29
What I have been doing for years now when I install BIG LIFT cams in my Kz1000 motors, I start out bringing the cam caps down into place with longer 6mm bolts. That way you grab a bunch of threads not just a couple!!! Then when I get the caps near to them being in place I remove the longer bolts one by one and replace them with the correct length bolts.
I have NEVER stripped the cam cap threads in my life doing it this way!!!!
1986 RG500G 2 stroke terror.
Last edit: 06 Jun 2025 16:29 by Dr. Gamma.
The following user(s) said Thank You: MFP-Joe, Street Fighter LTD, Dragbike_Mike, Gdizard, howardhb, Wookie58, kimchella, Kaw-boy 900 and 1 other people also said thanks.
- Kaw-boy 900
16 Jun 2025 17:27 - 16 Jun 2025 17:32
I like the longer bolts option too ! Any drillingl or/ and tap required ?
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
S1 250 triple 1973
H1, 500 triple 1975
LTD 1000, 1982
Ninja 1000R 1987
Ninja ZX12R 2006
KZ900 1976. My BB !
Yamaha RD 350 1973
Ducati 1098 2007
Last edit: 16 Jun 2025 17:32 by Kaw-boy 900.
- MJinCO
24 Nov 2025 05:49
What length studs should be used if converting to cam studs? Should they be installed like ARP does head bots, bottom out then screw out about 1 turn?
24 Nov 2025 06:01The stud and nut method I refer to is a temp assembly option. Once seated swop them out one at a time for the original bolts (I don't think there will be enough clearance to the cover as a permanent conversion without the nuts only being on a couple of threads when you start pulling it down)What length studs should be used if converting to cam studs? Should they be installed like ARP does head bots, bottom out then screw out about 1 turn?
- sf4t7
24 Nov 2025 10:39
Wookie is correct, I did some math and trial fits last winter and there isn't enough clearance to the valve cover for permanent studs - even if you use clamps to install the caps. Having enough stud length to end up with about 3 thread pitches above the nut when tight can still interfere with the valve cover.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
1974 Z1A
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
- zed1015
24 Nov 2025 11:38
To convert the caps to stud fit you need to spot face each cap at the 4 bolt locations to reduce their height.
The following user(s) said Thank You: rstnick, sf4t7, Wookie58
- MJinCO
25 Nov 2025 05:50
Thanks, I will continue with the clamp and longer bolt system.
- kevski
25 Nov 2025 06:40
Done my first conversion to stud around 20 years ago, I milled a little out of cam cover to allow for any extra height, naturally had to clamp cams down to get the nuts on the studs, the studs were 8mm reducing to 6mm to go through caps, 2 lots of 8 studs with the shoulder lower on dowel locating ones.
