What you guys use for a piston base tool?
- Gdailey2112
- 82 KZ1100D1
20 May 2023 19:05
dunno I've only used the factory tool one time and was nice to use but it seems like those two U shaped jobbys could easily be duplicated. Anyone using anything else that also works well?
1982 KZ1100D1
- Kelly E
Re: What you guys use for a piston base tool?
20 May 2023 19:26
I've made a couple sets out wood. I sand them smooth to prevent splinters and use motor oil for sealer.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1980 Suzuki GS 1100E
1982 Honda CB 900F Super Sport
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
1983 Honda CB 1100F
And more
The following user(s) said Thank You: Gdailey2112
- Gdailey2112
- 82 KZ1100D1
20 May 2023 20:56
wondering mostly what the dimensions are for those two long U shaped rods
1982 KZ1100D1
21 May 2023 04:16
Are you asking about the coathanger sized U shaped ones that go under the pistons to hold them all at the same elevation?
- Gdailey2112
- 82 KZ1100D1
21 May 2023 13:01 - 21 May 2023 13:03
Yes but I think it likely needs to be wire of a specific gauge just a little larger gauge than a wire coat hanger maybe even 2x thicker than.
sure does make one helluva difference on doing the task lowering the jugs.
1982 KZ1100D1
Last edit: 21 May 2023 13:03 by Gdailey2112.
21 May 2023 15:36 - 21 May 2023 15:58
You will find Joe at Pitstop tells you all you will need to know and has easy dimensions for the piston holding wood block They work great from my personal experience Dave file:///C:/Users/Dave%20A/Documents/Top%20End%20Assembly%20_%20pitstopperformance.html
My computer hates me.. Let me try and fix it for the pitstop performance link
Last edit: 21 May 2023 15:58 by Street Fighter LTD.
21 May 2023 19:22I made a couple out of coathangers. Worked fine.Yes but I think it likely needs to be wire of a specific gauge just a little larger gauge than a wire coat hanger maybe even 2x thicker than.
- slmjim+Z1BEBE
22 May 2023 05:21
Wire coat hangers with enough layers of shrink wrap to achieve the necessary diameter & protect aluminum surfaces.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com/index.html/
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- krazee1
22 May 2023 08:30 - 25 Jun 2023 17:34That is a GREAT suggestion! (IMHO) Pistons other than OEM will have varying skirt heights, so this is a great idea to change the diameter of the rods.Wire coat hangers with enough layers of shrink wrap to achieve the necessary diameter & protect aluminum surfaces.
Good Ridin'
slmjim & Z1BEBE
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
1974 Z1
1978 KZ1000 LTD
1980 KZ750E
Last edit: 25 Jun 2023 17:34 by KZQ.
- Dr. Gamma
22 May 2023 13:04
Like a fool a few years back I had to sell my Kawasaki Kz1000 ring compressor tool. I used that Kawasaki tool on 72mm and 73mm pistons on my Kz1000 motors. I still regret selling that ring compressor to this day. What I use now are the band type ring compressor tools. Only need two of them. You do the two inner pistons first, then the outer two. I use two pieces of wood cut to fit the pistons I am using in that motor to sit level as I then slide the barrel down on to those two inner pistons. Then I move the two outer pistons to near TDC and then level those pistons and gently tap the barrel down over the last two pistons. Still wish I had my fancy Kawasaki ring compressor tool......
1986 RG500G 2 stroke terror.
The following user(s) said Thank You: Gdailey2112, howardhb
- Cra-z1
23 May 2023 20:40I like these Honda Ring compressors for the CB450 and The piston blocks are 1/2 inch MDF with correct cutout for the rod and long enough to support the piston.
- Gdailey2112
- 82 KZ1100D1
24 May 2023 11:13
Great ideas for sure! Thanx so much
1982 KZ1100D1
