water cooled tig torch?
  • jus1975
  • jus1975's Avatar Topic Author
  • www.tripleaperformance.com
04 Dec 2020 10:29
#839359
I purchased a used miller synchrowave 350 with a cooler attachment. Im having a problem hooking the torch up. The torch water lines are not labeled so how could I determine the in/out. Or does it matter.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: water cooled tig torch?
04 Dec 2020 10:40
#839362
Call Miller . They will know.
I dont think it matters as it is just coolant flow , But Please check
  • jus1975
04 Dec 2020 10:43
#839363
Ill try calling. I sent an email awhile ago but never got a reply.
Thanks
  • Moderator
  • Moderator
04 Dec 2020 12:23
#839365
Try a local Virginia dealer .
I looked up on google and you have a number of shops that sell and service Miller welders
Just a thought
  • jus1975
04 Dec 2020 13:02
#839368
Hell of an idea. Where I get my gas is a miller dealer. Didn't think to ask but I will . Thanks again
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
04 Dec 2020 16:40
#839380
Not sure if this will be of any help, but this link is for a pdf owners manual for what may well be your welder.
www.millerwelds.com/files/owners-manuals/O363AT_MIL.pdf
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • jus1975
04 Dec 2020 21:36
#839398
thanks. I have that but mine is an older model with external cooler.
  • gd4now
  • gd4now's Avatar
05 Dec 2020 08:38
#839410
OK as I said not sure it would be of any help. I would assume you have looked at other owners manuals on the Miller site. I have noticed there are some on the external cooling system.
1977 KZ650 B1
  • SWest
  • SWest's Avatar
  • 10 22 2014
05 Dec 2020 09:39
#839412
On Jeff's machine he hooks it up to a hose bib and the other line drains on the ground. Doesn't take any pressure just enough to cool it.
  • Moderator
  • Moderator
05 Dec 2020 12:21
#839426
THe Miller 350 we used to have in our shop had a Miller coolant unit sitting on top of it that circulates coolant but I dont remember line routing
  • jus1975
05 Dec 2020 13:15
#839430
That's exactly how it is on mine. Ill try the local dealer monday
