What the heck are these socket things?!
- Sheath
27 Oct 2020 12:21
Hey everyone, I just picked these up in a box full of shims and all sorts, all they have is a number and usa on each one, inside each one is simply a thin bit of steel! What are they for?!!
Attachment 20201027_184257.jpg not found
Attachment 20201027_184254.jpg not found
Attachment 20201027_184246.jpg not found
Attachment 20201027_184210.jpg not found
Attachment 20201027_184149.jpg not found
Attachment 20201027_184145.jpg not found
Attachment 20201027_184117.jpg not found
Re: What the heck are these socket things?!
27 Oct 2020 12:34 - 27 Oct 2020 12:48
Looks like sockets for the valve clearence adjustment screws on the rocker arms.
Attachment ventileeinstellen101.jpg not found
Attachment ventileeinstellen102.jpg not found
Last edit: 27 Oct 2020 12:48 by Scirocco.
The following user(s) said Thank You: Sheath
- Sheath
27 Oct 2020 12:51
Ahhhh now that would make sense because the box these were in contains mainly oem valve shim stuff!
thanks
Attachment 20201027_185104.jpg not found
Attachment 20201027_184608.jpg not found
Attachment 20201027_184555.jpg not found
Attachment 20201027_184525.jpg not found
Attachment 20201027_184518.jpg not found
Attachment 20201027_184102.jpg not found
Attachment 20201027_184055.jpg not found
- Kidkawie
- I bleed premix
27 Oct 2020 20:54
Tap sockets. Square drive inside for tapping holes with 3/8 rachet. I have a similar set with an internal oring.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
The following user(s) said Thank You: SWest, Sheath
- Sheath
