metric
- Hawghunter
metric
24 Mar 2020 17:12
I have never used metric. Brought a set down to the kz. Before I round off these bolts I want to ask, is this a normal fit. Seems like a lot of play. Threads are very clean, some blaster has soaked in. Torque is not high on these engine bolts. 17 and 29 pounds.
1981 KZ550-A2
touring Red Rocks of Arizona on my KZ Red Rocket
- Hawghunter
Re: metric
24 Mar 2020 17:15
vid 1
1981 KZ550-A2
- Hawghunter
Re: metric
24 Mar 2020 17:16
vid 2
1981 KZ550-A2
- Hawghunter
Re: metric
24 Mar 2020 17:20
played when i uploaded it. So I submitted, doesnt show.
1981 KZ550-A2
- M_a_t_t
Re: metric
24 Mar 2020 17:33
I just use the wrench that fits the tightest. I bring out both standard and metric on everything I work on. I end up using them together like its a single set. If a 14 is too small and a 15 is sloppy I try a 9/16 (14.28mm)
Is the video uploaded to youtube and linked here or some other way?
83 KZ1100A (shaft)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
90 Honda CBR600F (brother's)
17 Versys X 300 abs
81 kz650h1
81 kz750e2
- Nerdy
Re: metric
24 Mar 2020 18:44
It's a good idea to use 6-point sockets whenever possible: you'll get a better fit than you will with a 12-point.
Unfortunately most sets are 12-point. If you want 6-point you'll probably need to buy a different set.
1967 Yamaha YCS1 Bonanza
1980 KZ440B
1981 Yamaha XT250H
1981 KZ440 LTD project bike
1981 GPz550
2013 Yamaha FZ6R
Re: metric
24 Mar 2020 19:01Nerdy wrote: It's a good idea to use 6-point sockets whenever possible: you'll get a better fit than you will with a 12-point.
+1
Twelve pointers are great for rounding off corners.
Re: metric
24 Mar 2020 20:13
You should get a set of 3/8 sockets. The ones most used are 10, 12, 13, 14, 15 and 17 mm. You should also get a set of JIS screwdrivers. Phillips will damage the heads.
Re: metric
25 Mar 2020 05:03hardrockminer wrote: You should get a set of 3/8 sockets. The ones most used are 10, 12, 13, 14, 15 and 17 mm. You should also get a set of JIS screwdrivers. Phillips will damage the heads.
10, 12, 14, 17, 19 are most common. Very few 13 and 15 on Japanese motorcycles.
Believe it or not but the Harbor Freight wrenches and sockets are good value for the money.
- Hawghunter
Re: metric
25 Mar 2020 10:58
thank you all. My sockets did not come with large enough sizes so I got a set of box and open end wrenches. the box end are 12 point. I will find some larger sockets. .
1981 KZ550-A2
- Hawghunter
Re: metric
25 Mar 2020 11:25
3
1981 KZ550-A2
Re: metric
25 Mar 2020 13:10 - 25 Mar 2020 13:13
So here some advantage and dis-advantage of the diffrent socket Driver systems
Good for normal torque
Better for high torque and fu*k up bolts and nuts
A new Driver System that can handle Inch/metric and fu*k up bolts and nuts in one tool
Last edit: 25 Mar 2020 13:13 by Scirocco.
The following user(s) said Thank You: Hawghunter
