Best penetrant part 53.6
19 Dec 2018 07:56
- old_kaw
Re: Best penetrant part 53.6
19 Dec 2018 08:12
I don't know how they all compare in terms if effectiveness, but the PB Blaster is some NASTY smelling stuff. AND in turn when you use it, YOU become some nasty smelling stuff. Use at your own risk.
PS: I have not watched the video yet.
1981 Kawasaki Kz1000K1
19 Dec 2018 08:28 - 19 Dec 2018 08:31
For the homemade concoction what would be a good ATF to use? I don't think they're all the same.
I've had good luck using Liquid wrench penetrating spray lubricant which has worked very good in various applications, including some EGR valve bolts which are purported to be difficult to remove. I did try acetone + Ford ATF on some exhaust manifold heat shield bolts but can't really say if it was any better or worse than LW.
Last edit: 19 Dec 2018 08:31 by martin_csr.
- old_kaw
19 Dec 2018 08:43 - 19 Dec 2018 08:43
Replying to Martin's DIY penetrant, I have been told WD is just kerosene, or diesel fuel.
As far as brand name penetrants, I usually use WD, but prefer Seafoam brand "Deep Creep" (not in video) but it is ~$11.00 for a spray can, where as WD is ~6 bucks for a can.
I don't care much for the WD squirter nozzle either since after it gets tossed around in my tool bucket a few thousand times, it becomes pretty much usable on a half full can. (service tech work).
Last edit: 19 Dec 2018 08:43 by old_kaw.
19 Dec 2018 09:29
When you say wd, do you mean regular wd-40 or one of their new wd40 penetrating oils? Because regular wd40 isn't really a penetrant. : )
- old_kaw
19 Dec 2018 10:44martin_csr wrote: When you say wd, do you mean regular wd-40 or one of their new wd40 penetrating oils? Because regular wd40 isn't really a penetrant. : ) ...
Yes Martin. WD-40
This stuff.
- 2strokerider
Last edit: 19 Dec 2018 14:57 by 2strokerider.
19 Dec 2018 16:56
WD-40 is a petrochemical cleaner/carrier along with light oil. The MSDS can be found online.
19 Dec 2018 17:13
Based on a recommendation from a very experienced engineer friend of mine I use Kano Kroil. Over the past couple decades I've used it on some extremely stubborn bolts & screws and it has always worked extremely well. I let them soak for 2 or 3 days and Kroil breaks the bond. Here's the flavor I use. Ed
www.kanolabs.com/google/
The following user(s) said Thank You: BCScott
- KZB2 650
20 Dec 2018 05:07
Was glad to see Liq wrench do so well.......... always what my dad used and me as well.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- slmjim+Z1BEBE
20 Dec 2018 06:19
Oil thread 2.0
Where's that popcorn emoji when you need one?
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
20 Dec 2018 06:50slmjim+Z1BEBE wrote: Oil thread 2.0
Good Ridin'
slmjim & Z1BEBE
:whistle:
