Motorcycle Table Project
  • NakedFun
  • NakedFun's Avatar Topic Author
20 Aug 2016 04:36
#739275
So I have been planning for a build table for a while and looked at pre-made stuff and sketched my own design. Well surfing Craigslist recently yielded an interesting prospect to start with. I went up just across the SC / NC boarder and met a really interesting person and made the deal. For $180 I got this:
[IMG
Upon further research is a modified, Mid-70's American Lift industrial table. It was modified and came out of a furniture factory that closed and this guy bought 3 of them. So I first cut some 3/4" table drop ins for the ends which extend the .125" think steel table from 3' x 5' to 3' x 8'. I have a couple extra chocks that I retrofitted and will pin to the table and had to use a couple of bottle jacks to lift it up. The thing is well over 600lbs. Looking at the underside it has a 5.5" Cylinder (2.5" Ram) and 1.5" thick solid steel double scissor lift arms....Turns out it appears that this table was rated for 6,000 lbs from what I can tell from researching the table. Should be enough for bikes.....lol
[IMG
[IMG
The motor works, but is a 3 phase 230/460 motor so I knew right away I was going to have to change that. Once I had the table up and supported, started pulling it apart, cleaning it, and researching. Motor was hard to find due to the NEMA and CZ mounting for the pump directly. I kept at it and found a new Baldor 1 hp (Original was 1.5hp) that was on Ebay. Made a deal for $200 shipped and it arrived yesterday.
[IMG
So I mapped out the electrical and have my plan for rewire. Due to the motor size, I am going to have to reconfigure it and mount the box external of the pan.
[IMG
So redoing the tank, new flexible cylinder line, and I'll have to bend new hard lines for the reconfig. The bed will be Raptor Lined, and frame painted gloss black. That is it for now more to come.
Cory
2008 Kawasaki Concours 14
1999 Kawasaki ZRX1100
1976 Kawasaki KZ900
  • davido
  • davido's Avatar
Re: Motorcycle Table Project
20 Aug 2016 05:21
#739276
A Motorcycle Table;
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • NakedFun
20 Aug 2016 05:32
#739277
davido wrote: A Motorcycle Table;
Very nice....Harley's are always parked, would have made better candidates! Lol
Cory
Cory
1976 Kawasaki KZ900
  • GPzMOD750
  • GPzMOD750's Avatar
20 Aug 2016 06:27
#739280
Very nice. Looks like you could change the oil on an elephant on that thing. It must weigh a ton.
I was thinking of doing my own lift but I punked out and went to Harbor Junk with my $300 coupon. Now the problem is that I only have one and I'm soon to have 3 bikes.
  • NakedFun
20 Aug 2016 06:43
#739282
Well I have three bikes and up to this pint only had stands, so the table was really only for service. Keep your bikes alternating service and you should be good!
Cory
1976 Kawasaki KZ900
  • GPzMOD750
20 Aug 2016 07:55 - 20 Aug 2016 13:26
#739291
It seems I always have a long term project hogging the table and I still am creeping around on the garage floor for minor repairs and maintenance on the others....
It will improve I hope. I'm parting out the big project and hopefully the new semi-long term project wont take too long.
Last edit: 20 Aug 2016 13:26 by GPzMOD750.
  • kaw-a-holic
  • kaw-a-holic's Avatar
20 Aug 2016 12:17
#739308
Very cool Cory.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • Givusaclue
  • Givusaclue's Avatar
27 Aug 2016 14:41
#740161
www.customfighters.com/forums/showthread.php?t=50726
this is probably the most professional looking home made bike lift i've ever seen
  • NakedFun
03 Sep 2016 16:03
#741000
Little more work done. Bent up two new lines, trimmed up the tank, and made a new top plate with filtered breather cap. I screwed up one line, so I need to get some more 3/8" steel line and I can finish it up tomorrow. Get it mounted and wired to try it out.
[IMG
Cory
1976 Kawasaki KZ900
  • NakedFun
16 Sep 2016 17:51 - 16 Sep 2016 18:01
#742556
Ding ding.....
vid636.photobucket.com/albums/uu83/fedwi...0076_zps6yluntaw.mp4
Have to be careful as with over 44" of lift I can put the bike into the garage door.... Lol
Cory
1976 Kawasaki KZ900
Last edit: 16 Sep 2016 18:01 by NakedFun.
  • 750 R1
  • 750 R1's Avatar
16 Sep 2016 18:40
#742562
NakedFun wrote: Ding ding.....
Cory
On your next holiday to Australia, can you bring that with you..? :P
  • NakedFun
16 Sep 2016 18:43
#742563
Cory
Table weighs over 600lbs.....might not be allowed on the plane....
Cory
1976 Kawasaki KZ900
