JIS screwdrivers
- ThatGPzGuy
Re: JIS screwdrivers
16 May 2015 08:22Agreed. One of the best tool investments. I like the magnetic tip.650ed wrote: Yes indeed - Vessel makes quality screwdrivers. Ed
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
20 May 2015 05:40
Here's a picture that helps describe the difference between Phillips and JIS screwdriver tips. It shows a comparison between the pointed end of the Phillips and the flat end of the JIS tips. That pointed end of the Phillips is the reason it will bottom out in a JIS screw before the blades are fully seated. Ed
20 May 2015 06:17
I read somewhere that, originally, the reason phillips screwdrivers were made that way was so the factory workers wouldn't over-torque the screws, so they are supposed to slip out of the screw heads by design.
20 May 2015 07:00martin_csr wrote: I read somewhere that, originally, the reason phillips screwdrivers were made that way was so the factory workers wouldn't over-torque the screws, so they are supposed to slip out of the screw heads by design.
I have read that too, and I believe it is true since phillips screwdriver tips do tend to slip out (cam out) if excessive force is applied. The link below describes it. Ed
en.wikipedia.org/wiki/Cam_out
- Kidkawie
- I bleed premix
20 May 2015 10:31
JIS has a dot.
ecx.images-amazon.com/images/I/51l2LeFKrPL._SX342_.jpg
Jap bikes still have them, I'm constantly reading about people who can't get the float bowl screws out. lol
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- TheForumTroll
13 Aug 2015 16:09
None of my JIS screws has dots on them. Maybe some company out there does that but there aren't any on my KZ.
-[ KZ700-A1 '84 ]-
- loudhvx
13 Aug 2015 20:35 - 13 Aug 2015 20:37
Even if you correct the tip issue with the Philips driver, there are other differences (like the cam-out-causing angle and the inner corner of the cross is sharper on a JIS) which will result in deformation of a JIS screw when using a Philips, especially when tight. Back in the day, there was no info on how to get JIS screwdrivers...or even that they existed. So I have a few philips that are converted, but they still don't work as nice as the tool purposely designed for the job.
BTW, you don't have to convert to allens... you can get metric screws with actual Philips heads too. But allens are so nice.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 13 Aug 2015 20:37 by loudhvx.
13 Aug 2015 21:06
I lived with mine for 40 years. Always wanted SS Allens. This time around I used them. I will never go back. The JIS rusts. The Allens don't.
- GKBO
- Saving old"dead" bikes
14 Oct 2015 13:51
There is a new supplier of JIS screwdrivers
www.gofastinnovations.com/
,Z1 sells the same ones as well.
www.z1enterprises.com/ListItems.aspx?pro...p=0+JIS+Screwdrivers
.Got a set coming from the first link
14 Oct 2015 15:19GKBO wrote: There is a new supplier of JIS screwdrivers www.gofastinnovations.com/ ,Z1 sells the same ones as well. www.z1enterprises.com/ListItems.aspx?pro...p=0+JIS+Screwdrivers .Got a set coming from the first link
Company owner is a member of GS Resources. A motorcycle guy.
- GKBO
15 Oct 2015 14:55
He most certainly is.Does some drag racing IIRC. Getting them direct is a no brainer for a Canadian,$24.95 with no extra for shipping..Great deal for us Canadians.
- bl_francis
06 Nov 2015 13:31
My JIS drivers were some of the best money I ever spent. Thanks for the heads-up guys!
1987 KZ1000 Police
