can anyone I'd this fastener
- dkoz
Re: can anyone I'd this fastener
13 Dec 2014 12:05
The whole thing spins .rubber washer and all ..that's a good idea patton..neidle nose, ,vise grips, ,you name it just keeps popping off..I will give patrons idea a try..
1978 LTD B2 smashed
1978 Z1R D1
1978 A2
1978 Z1R D1
1978 A2
- bluezbike
14 Dec 2014 12:09 - 14 Dec 2014 12:10
If the whole thing just spins one of two things has happened........1 - the prongs have sheared off (best situation) ---- just remove the bolt that was in it and push it out from the bolt side, it should just pop right off then replace with a new one. 2 - the prongs have spun around the piece they were embedded in effectively drilling out a very large hole ---- and that is a bear to repair as you have to fill in the fiberglass (I take it this was in a fairing from a previous comment) with all the attendant issues of strength, paint etc., then drill in a new small hole and put in a new fitting.
Hth
Hth
79 KZ 1000 LTD
Last edit: 14 Dec 2014 12:10 by bluezbike.
